[postgis-users] Topology performance test
Stefano Iacovella
stefano.iacovella at gmail.com
Fri Jun 22 00:09:53 PDT 2012
2012/6/21 Sandro Santilli <strk at keybit.net>:
> On Thu, Jun 21, 2012 at 06:12:15PM +0200, Stefano Iacovella wrote:
>> Sandro, I run
>> $:~/sources/geos-3.3.3$sudo make uninstall
>> then
>> stefano at ubuntu1204vm:~/sources/geos-3.3.3$ ll /usr/local/lib/
>> drwxr-xr-x 2 root root 4096 Apr 27 16:10 geos/
>> -rwxr-xr-x 1 root root 15504429 Apr 27 16:10 libgeos-3.3.3.so*
>> -rwxr-xr-x 1 root root 866246 Apr 27 16:10 libgeos_c.so.1.7.4*
>> Should "make uninstall" delete the two libgeos file?
> Unless you configured the build to have a different prefix.
No I didn't
I installed 3.3.3 by
./configure
make
sudo make install
sudo ldconfig
make clean
Before dealing with 3.3.4 I tried to delete the two files and install
again 3.3.3 with
./configure
make
sudo make install
sudo ldconfig
then
ll /usr/local/lib
total 50624
drwxr-xr-x 5 root root 4096 Jun 22 08:57 ./
drwxr-xr-x 11 root root 4096 May 2 14:38 ../
-rwxr-xr-x 1 root root 15504429 Jun 22 08:57 libgeos-3.3.3.so*
-rw-r--r-- 1 root root 31419116 Jun 22 08:57 libgeos.a
-rw-r--r-- 1 root root 1238562 Jun 22 08:57 libgeos_c.a
-rwxr-xr-x 1 root root 957 Jun 22 08:57 libgeos_c.la*
lrwxrwxrwx 1 root root 18 Jun 22 08:57 libgeos_c.so ->
libgeos_c.so.1.7.4*
lrwxrwxrwx 1 root root 18 Jun 22 08:57 libgeos_c.so.1 ->
libgeos_c.so.1.7.4*
-rwxr-xr-x 1 root root 866246 Jun 22 08:57 libgeos_c.so.1.7.4*
-rwxr-xr-x 1 root root 925 Jun 22 08:57 libgeos.la*
lrwxrwxrwx 1 root root 16 Jun 22 08:57 libgeos.so -> libgeos-3.3.3.so*
And running sudo make uninstall deleted all the files in
/usr/local/lib (uhm geos related files I mean :) )
So there is no issue at all but for the sake of my understanding I
wonder if there was some link to the geos library preventing make from
uninstall them?
thank you very much for your help
Cheers
Stefano
>> It is safe if I delete them and then install geos-3.3.4?
> Yes.
> --strk;
> postgis-users mailing list
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
