[postgis-users] Proper way to upgrade after using CREATE EXTENSION postgis?
Charlie Sharpsteen charles.sharpsteen at gmail.com
Mon Jun 25 11:02:44 PDT 2012
Hello all,
I installed PostGIS 2.0 and added it to a database using:
    CREATE EXTENSION postgis;
Today, I built and installed 2.0.1 and tried to upgrade the extension using:
    ALTER EXTENSION postgis UPDATE;
However, this failed with:
    ERROR:  cannot drop cast from geometry to geometry because extension
postgis requires it
    HINT:  You can drop extension postgis instead.
So, I tried the old school way of running the upgrade scripts:
    psql -f /usr/local/share/postgis/postgis_upgrade_20_minor.sql
hum_bay_gis
But this also fails:
BEGIN
CREATE FUNCTION
       postgis_major_version_check
 Scripts versions checked for upgrade: ok
(1 row)
DROP FUNCTION
psql:/usr/local/share/postgis/postgis_upgrade_20_minor.sql:46: ERROR:
 cannot drop function addgeometrycolumn(character varying,character
varying,character varying,character varying,integer,character
varying,integer,boolean) because extension postgis requires it
psql:/usr/local/share/postgis/postgis_upgrade_20_minor.sql:47: ERROR:
 current transaction is aborted, commands ignored until end of transaction
block
...(thousands of similar errors)...
ROLLBACK
So, it appears there is no way to upgrade PostGIS without running `DROP
EXTENSION postgis` which would cascade to all spatially-enabled tables.
Am I missing a step or is there a circular dependency here that is breaking
the upgrade process?
-Charlie
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120625/81857a5f/attachment.html>
