[postgis-users] Proper way to upgrade after using CREATE EXTENSION postgis?
Sandro Santilli strk at keybit.net
Mon Jun 25 12:08:43 PDT 2012
On Mon, Jun 25, 2012 at 11:02:44AM -0700, Charlie Sharpsteen wrote:
> Hello all,
> I installed PostGIS 2.0 and added it to a database using:
>     CREATE EXTENSION postgis;
> Today, I built and installed 2.0.1 and tried to upgrade the extension using:
>     ALTER EXTENSION postgis UPDATE;
> However, this failed with:
>     ERROR:  cannot drop cast from geometry to geometry because extension
> postgis requires it
>     HINT:  You can drop extension postgis instead.
> So, I tried the old school way of running the upgrade scripts:
>     psql -f /usr/local/share/postgis/postgis_upgrade_20_minor.sql
> hum_bay_gis
> But this also fails:
> BEGIN
> CREATE FUNCTION
>        postgis_major_version_check
>  Scripts versions checked for upgrade: ok
> (1 row)
> DROP FUNCTION
> psql:/usr/local/share/postgis/postgis_upgrade_20_minor.sql:46: ERROR:
>  cannot drop function addgeometrycolumn(character varying,character
> varying,character varying,character varying,integer,character
> varying,integer,boolean) because extension postgis requires it
> psql:/usr/local/share/postgis/postgis_upgrade_20_minor.sql:47: ERROR:
>  current transaction is aborted, commands ignored until end of transaction
> block
> ...(thousands of similar errors)...
> ROLLBACK
> So, it appears there is no way to upgrade PostGIS without running `DROP
> EXTENSION postgis` which would cascade to all spatially-enabled tables.
> Am I missing a step or is there a circular dependency here that is breaking
> the upgrade process?
I had a similar experience with EXTENSION, so much that I decided not to
use it again. It's a bad step back from safe and well-tested old school way.
I hope you've a way to break out of the EXTENSION dependency jail somehow.
Please report back when you figure.
--strk;
 Sent from our free software
 http://www.gnu.org/philosophy/free-sw.html
