[postgis-users] Proper way to upgrade after using CREATE EXTENSION postgis?
Paragon Corporation
lr at pcorp.us
Mon Jun 25 13:33:06 PDT 2012
It worked fine for me upgrading from 2.0.0 to 2.0.1.
I used:
ALTER EXTENSION postgis UPDATE TO "2.0.1";
Which version of PostGIS are you using.
do a
SELECT postgis_full_version()l
When all fails, to fix your database.
1) Backup your database
2) Restore it.
It should automatically upgrade itself to the new version.
Hope that helps,
Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Sandro Santilli
> Sent: Monday, June 25, 2012 3:09 PM
> To: PostGIS Users Discussion
> Cc: postgis-users at googlegroups.com
> Subject: Re: [postgis-users] Proper way to upgrade after
> On Mon, Jun 25, 2012 at 11:02:44AM -0700, Charlie Sharpsteen wrote:
> > Hello all,
> > I installed PostGIS 2.0 and added it to a database using:
> > CREATE EXTENSION postgis;
> > Today, I built and installed 2.0.1 and tried to upgrade the
> extension using:
> > ALTER EXTENSION postgis UPDATE;
> > However, this failed with:
> > ERROR: cannot drop cast from geometry to geometry because
> > extension postgis requires it
> > HINT: You can drop extension postgis instead.
> > So, I tried the old school way of running the upgrade scripts:
> > psql -f /usr/local/share/postgis/postgis_upgrade_20_minor.sql
> > hum_bay_gis
> > But this also fails:
> > BEGIN
> > CREATE FUNCTION
> > postgis_major_version_check
> > Scripts versions checked for upgrade: ok
> > (1 row)
> > DROP FUNCTION
> psql:/usr/local/share/postgis/postgis_upgrade_20_minor.sql:46: ERROR:
> > cannot drop function addgeometrycolumn(character varying,character
> > varying,character varying,character varying,integer,character
> > varying,integer,boolean) because extension postgis requires it
> psql:/usr/local/share/postgis/postgis_upgrade_20_minor.sql:47: ERROR:
> > current transaction is aborted, commands ignored until end of
> > transaction block ...(thousands of similar errors)...
> > ROLLBACK
> > So, it appears there is no way to upgrade PostGIS without
> running `DROP
> > EXTENSION postgis` which would cascade to all
> spatially-enabled tables.
> > Am I missing a step or is there a circular dependency here
> that is breaking
> > the upgrade process?
> I had a similar experience with EXTENSION, so much that I
> decided not to
> use it again. It's a bad step back from safe and well-tested
> old school way.
> I hope you've a way to break out of the EXTENSION dependency
> jail somehow.
> Please report back when you figure.
> --strk;
> Sent from our free software
> http://www.gnu.org/philosophy/free-sw.html
> postgis-users mailing list
