[postgis-users] From Debian to Windows + major upgrading of PostgreSQL and PostGIS
Sandro Santilli strk at keybit.net
Thu Jun 28 07:32:03 PDT 2012
On Thu, Jun 28, 2012 at 10:23:14AM -0400, Mathieu Basille wrote:
> Dear list,
> I need to proceed with a sensitive (and unfortunate) migration of
> the computer which currently runs PostGIS from Debian to Windows. I
> figured out I could as well upgrade PostGIS and PostgreSQL in the
> process.
> Current versions are:
> - Debian Squeeze
> - PostgreSQL 8.4
> - PostGIS 2.0 SVN r6066 from 13 October 2010 (long before the
> extension mechanism was implemented)
> Target versions thus are:
> - Windows 7
> - PostgreSQL 9.1
> - PostGIS 2.0.1
> Did anyone already go through such a migration? From what I
> understand, I need to run a hard upgrade using pg_dump (or
> pg_dumpall) from PostgreSQL 9.1 first. I will then get a .sql file
> which contains the whole DB. I can then save it, install Windows 7 +
> PostgreSQL 9.1 + PostGIS 2.0.1, and use it again to restore the DB
> in the new PostgreSQL/PostGIS.
You'll need to invoke pg_dump using the -Fc (custom format) switch,
which gives you not an SQL but an indexed dump, needed for skipping
the parts you won't want to restore. postgis_restore.pl will take
care of the restore (and skipping).
And yes, I'd do the upgrade on Unix first.
Once you go to windows you'll be alone in the dark ...
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.1
  |  / 2.1 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
