[postgis-users] Topology : "topology.toTopoGeom" Error message
celati laurent
lcelati at latitude-geosystems.com
Fri Jun 29 00:12:40 PDT 2012
Hello,
I have a error message when i try to use new layer id in populating the
new topogeometry column :
SELECT topology.CreateTopology('topo_world', 4326);
CREATE TABLE nei_topo(gid serial primary key, id integer, classe_id
integer, descriptio character varying(80), Labels character varying(24));
SELECT topology.AddTopoGeometryColumn('topo_world', 'public',
'nei_topo_v2', 'topo', 'MULTIPOLYGON') As new_layer_id;
INSERT INTO nei_topo_v2(gid, id, classe_id, descriptio, labels, topo)
SELECT gid, id, classe_id, descriptio, Labels topology.toTopoGeom(the_geom, 'topo_world', 3)
FROM land_cover
WHERE gid BETWEEN 1 and 8;
ERREUR: erreur de syntaxe sur ou près de « . »
LINE 3: ...T gid, id, classe_id, descriptio, Labels topology.toTopoGeo...
********** Erreur **********
État SQL :42601
Caractère : 127
I send you by attachment : "land_cover" table & "nei-topo_v2" table. For
information, these 2 tables are in the public schema.
Could you throw light for me please? I don't succeed in populating the
new topogeometry column.
Could you show me my mistake, can you tell me what I should write
please? I would like make progress in topology tests...Thank you
Kind regards.
Laurent Celati – Geospatial applications specialist - LATITUDE GEOSYSTEMS
47, avenue de la Division Leclerc - 95170 Deuil-la-Barre, FRANCE
Tel : + 33 (0)1 34 17 23 84 - Fax : + 33 (0) 1 39 64 04 86
mob : + 33 (0)6 xx xx xx xx
skype lcelati
E-mail : lcelati at latitude-geosystems.com
http://www.latitude-geosystems.com
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120629/63e687af/attachment.jpe>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120629/63e687af/attachment-0001.jpe>
