[postgis-users] Install problem with PROJ directory
William Kyngesburye
woklist at kyngchaos.com
Fri Jun 29 20:46:14 PDT 2012
--with-projdir=/Library/Frameworks/PROJ.framework/unix
should work (it's how I make my postgis package). Configure will figure out the includes and other subdirs. You probably also need:
--with-gdalconfig=/Library/Frameworks/GDAL.framework/unix/bin/gdal-config
On Jun 29, 2012, at 8:53 PM, Bob Holmstrom wrote:
> Hello - very novice user here.
> I am doing a neighborhood history mapping project and want to use a MapBox template. In order to do so I need to "have PostgreSQL installed & running with a PostGIS database setup within it."
> I have an iMac model 8,1 running Snow Leopard 10.6.8
> I have downloaded and installed PostgreSQL 9.1 - The install ran as per the example shown in the www.enterprisedb.com/resources-community/pginst-guide
> I did not install any of the StackBuilder options as offered at the end of the install.
> I downloaded PostGIS after installing the GEOS and PROJ4 frameworks as per the osm2pgsql installer instructions. I also downloaded and installed XCODE in order to get access to a c++ compiler.
> ./configure apparently requires extensions to enable pg_config, GEOS, PROJ, and GUI?
> ./configure --with-pgconfig=/Library/PostgreSQL/9.1/bin/pg_config --with-geosconfig=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config seems to run correctly through pg_config and GEOS and generates the error "configure: error: could not find proj_api.h - you may need to specify the directory of a PROJ.4 installation using --with-projdir"
> The PostGIS install instructions say:
> --with-projdir=DIR
> Proj4 is a reprojection library required by PostGIS. Use this parameter (--with-projdir=/path/to/projdir) to manually specify a particular Proj4 installation directory that PostGIS will build against.
> I don't find any directory titled "projdir" and the file proj_api.h resides in the path /Library/Frameworks/PROJ.framework/Versions/Current/Headers/
> Can anyone help me with the appropriate form for the extra bit for the ./configure statement?
> Thanks
> Bob
> postgis-users mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
