[postgis-users] cannot make comments
Denis Rouzaud denis.rouzaud at gmail.com
Thu Mar 1 02:54:23 PST 2012
since yesterday, I cannot run make comments anymore.
I have filled ticket 1642
http://trac.osgeo.org/postgis/ticket/1642
Here is the output:
make -C doc comments
make[1]: Entering directory `/opt/postgis-2.0.0beta2SVN/doc'
cat postgis.xml | sed -e "s/@@LAST_RELEASE_VERSION@@/2.0.0beta2SVN/g" -e "s;@@MATHML_PATH@@;http://www.w3.org/Math/DTD/mathml2/mathml2.dtd;g">  postgis-out.xml
/usr/bin/xsltproc ./xsl/postgis_aggs_mm.xml.xsl postgis-out.xml>  postgis_aggs_mm.xml
/usr/bin/xsltproc ./xsl/postgis_comments.sql.xsl postgis-out.xml>  postgis_comments.sql
/usr/bin/xsltproc ./xsl/raster_comments.sql.xsl postgis-out.xml>  raster_comments.sql
/usr/bin/xsltproc ./xsl/topology_comments.sql.xsl postgis-out.xml>  topology_comments.sql
http://www.oasis-open.org/docbook/xml/4.5/ent/isonum.ent:1: parser error : Content error in the external subset
HTTP/1.1 200 OK
http://www.oasis-open.org/docbook/xml/4.5/ent/isonum.ent:1: validity error : All markup of the conditional section is not in the same entity
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
HTTP/1.1 200 OK
unable to parse postgis-out.xml
make[1]: *** [topology_comments.sql] Error 6
make[1]: Leaving directory `/opt/postgis-2.0.0beta2SVN/doc'
make: *** [comments] Error 2
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120301/74d3e3e1/attachment.html>
