[postgis-users] cannot make comments
Sandro Santilli
strk at keybit.net
Thu Mar 1 03:07:48 PST 2012
We changed the default so you get a chance to contribute a patch
for the REQUIREMENTS section of the README file :)
Before the change you would be able to build the comments but very
slowly fetching the DTD everytime. Now you have to install it in your
system (or bruteforce - instructions in the ticket and in the doc/Makefile.in).
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
On Thu, Mar 01, 2012 at 11:54:23AM +0100, Denis Rouzaud wrote:
> Hi,
> since yesterday, I cannot run make comments anymore.
> I have filled ticket 1642
> http://trac.osgeo.org/postgis/ticket/1642
> Here is the output:
> make -C doc comments
> make[1]: Entering directory `/opt/postgis-2.0.0beta2SVN/doc'
> cat postgis.xml | sed -e "s/@@LAST_RELEASE_VERSION@@/2.0.0beta2SVN/g" -e "s;@@MATHML_PATH@@;http://www.w3.org/Math/DTD/mathml2/mathml2.dtd;g"> postgis-out.xml
> /usr/bin/xsltproc ./xsl/postgis_aggs_mm.xml.xsl postgis-out.xml> postgis_aggs_mm.xml
> /usr/bin/xsltproc ./xsl/postgis_comments.sql.xsl postgis-out.xml> postgis_comments.sql
> /usr/bin/xsltproc ./xsl/raster_comments.sql.xsl postgis-out.xml> raster_comments.sql
> /usr/bin/xsltproc ./xsl/topology_comments.sql.xsl postgis-out.xml> topology_comments.sql
> http://www.oasis-open.org/docbook/xml/4.5/ent/isonum.ent:1: parser error : Content error in the external subset
> HTTP/1.1 200 OK
> http://www.oasis-open.org/docbook/xml/4.5/ent/isonum.ent:1: validity error : All markup of the conditional section is not in the same entity
> HTTP/1.1 200 OK
> HTTP/1.1 200 OK
> HTTP/1.1 200 OK
> HTTP/1.1 200 OK
> unable to parse postgis-out.xml
> make[1]: *** [topology_comments.sql] Error 6
> make[1]: Leaving directory `/opt/postgis-2.0.0beta2SVN/doc'
> make: *** [comments] Error 2
