[postgis-users] Spatial column from text via a VIEW, Possible?
Bob Basques Bob.Basques at ci.stpaul.mn.us
Tue Mar 6 09:10:52 PST 2012
All,
made nice progress from Simon's suggestions, but . . .
Ok, I'm probably trying to push this harder than I need to, but, I'm trying to ST_Transform the data from 4326 to 200068 (Our private projection) in the construction of the view, but I keep hitting permission errors.
NOTE: we use the 200068 projection for all of our data, have for years.  It's definition in SPATIAL_REF_SYS is correct.
This works fine:
select
           ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326) as geom,
           ST_AsText(ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326)) as geom_text
      from
          (select rxtime,
                  split_part(cmd, ',', 3) as part3,
                  split_part(cmd, ',', 4) as part4
             from
                  cmdstpinfo
            where cmd
             like '>Plot:%') AS first_pass;
But this give me an error, do I have the ST_Transform in the right spot, is 8.4.2 too old of a release? :
select
           ST_AsText(ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326)) as geom_text,
           ST_AsText(ST_Transform(ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326)), 200068) as geom_city
      from
          (select rxtime,
             from
                  cmdstpinfo
            where cmd
Like:
ERROR:  function st_transform(geometry) does not exist
LINE 4:            ST_AsText(ST_Transform(ST_SetSRID(ST_MakePoint(pa...
HINT:  No function matches the given name and argument types. You might need to add explicit type casts.
********** Error **********
SQL state: 42883
Hint: No function matches the given name and argument types. You might need to add explicit type casts.
Character: 212
Thanks
bobb
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120306/d25de96d/attachment.html>
