[postgis-users] Spatial column from text via a VIEW, Possible?
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Tue Mar 6 10:32:49 PST 2012
Ok, it looks like I may not have PROJ support compiled in, but wouldn't the existence of the SPATIAL_REF_SYS mean that PROJ is installed??
bobb
>>> "Bob Basques" <Bob.Basques at ci.stpaul.mn.us> wrote:
All,
made nice progress from Simon's suggestions, but . . .
Ok, I'm probably trying to push this harder than I need to, but, I'm trying to ST_Transform the data from 4326 to 200068 (Our private projection) in the construction of the view, but I keep hitting permission errors.
NOTE: we use the 200068 projection for all of our data, have for years. It's definition in SPATIAL_REF_SYS is correct.
This works fine:
select
ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326) as geom,
ST_AsText(ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326)) as geom_text
from
(select rxtime,
split_part(cmd, ',', 3) as part3,
split_part(cmd, ',', 4) as part4
from
cmdstpinfo
where cmd
like '>Plot:%') AS first_pass;
But this give me an error, do I have the ST_Transform in the right spot, is 8.4.2 too old of a release? :
select
ST_AsText(ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326)) as geom_text,
ST_AsText(ST_Transform(ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326)), 200068) as geom_city
from
(select rxtime,
from
cmdstpinfo
where cmd
Like:
ERROR: function st_transform(geometry) does not exist
LINE 4: ST_AsText(ST_Transform(ST_SetSRID(ST_MakePoint(pa...
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
********** Error **********
SQL state: 42883
Hint: No function matches the given name and argument types. You might need to add explicit type casts.
Character: 212
Thanks
bobb
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120306/da35ac98/attachment.html>
