[postgis-users] problem with raster2pgsql
Bborie Park bkpark at ucdavis.edu
Thu Mar 8 12:05:22 PST 2012
Correct.  GDAL 1.9 works fine as long as the table has a rid column.
rtpostgis_legacy.sql is not needed.
gdalinfo PG":host=localhost dbname='test' user='USERNAME'
password='PASSWORD' table='aspect' mode=2"
The above command works for me with GDAL 1.9 and GDAL trunk.
-bborie
On 03/08/2012 11:46 AM, Pierre Racine wrote:
> Ok. So it is clear for me as well: GDAL 1.9 works well with PostGIS 2.0 as soon as the table has a rid column. There is no need for rtpostgis_legacy.sql...
> So as soon as people get problem with QGIS they should first test with GDAL so we can circumscribe the problem to GDAL or to the QGIS plugin.
> I'm testing more.
> Pierre
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>> bounces at postgis.refractions.net] On Behalf Of Bborie Park
>> Sent: Thursday, March 08, 2012 2:41 PM
>> To: postgis-users at postgis.refractions.net
>> Subject: Re: [postgis-users] problem with raster2pgsql
>> It works.
>> On 03/08/2012 11:33 AM, Pierre Racine wrote:
>>>> As for GDAL 1.9, everything is the same.
>>> You mean? It works or it does not?
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
