[postgis-users] Are there any Ubuntu PPAs that serve PostGIS 2.0 beta releases?
Stephen V. Mather
svm at clevelandmetroparks.com
Wed Mar 14 13:10:43 PDT 2012
For compiling 2.0 for Ubuntu, I’d recommend doing a custom build of GDAL 1.9 with GEOS 3.3.2—otherwise you’ll have the package manager bringing in GEOS 3.2.x for GDAL 1.7, and then you’ll have two GEOS libraries floating out there… . Might fix the problem below too.
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
<http://www.clemetparks.com/> clevelandmetroparks.com
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Charlie Sharpsteen
Sent: Wednesday, March 14, 2012 4:01 PM
To: postgis-users at googlegroups.com
Cc: Charlie Sharpsteen; PostGIS Users Discussion
Subject: Re: [postgis-users] Are there any Ubuntu PPAs that serve PostGIS 2.0 beta releases?
On Wednesday, March 14, 2012 8:44:16 AM UTC-7, Charlie Sharpsteen wrote:
On Wednesday, March 14, 2012 8:40:22 AM UTC-7, Charlie Sharpsteen wrote:
It does look like a GDAL upgrade to 1.9 would be a good idea though if the final version will require it. I have plenty of experience building this stuff from maintaining most of the GIS stack for the Homebrew package manager on OS X. Entirely new to Debian packaging though, so that will slow me down quite a bit.
-Charlie
Actually, after re-reading the installation notes, it doesn't look like GDAL 1.9 is mandatory---just that GDAL >= 1.6 will be mandatory once PostGIS 2.0 is released.
-Charlie
Allright, took a few jabs at this and here is what I have found so far:
- Without GEOS 3.3.2, PostGIS must be configured `--without-topology` so this definitely knocks out a big chunk of 2.0 functionality.
- 2.0.0beta2 can compile against the dependencies supplied for PostGIS 1.5.x via `apt-get build-dep postgis` with the addition of GDAL 1.7.0 via `apt-get install libgdal1-dev`. However, 2.0.0beta3, released today, and the current SVN head fail during configure:
RASTER: Raster support requested
checking for GDAL >= 1.6.0... found
checking gdal.h usability... yes
checking gdal.h presence... yes
checking for gdal.h... yes
checking ogr_api.h usability... yes
checking ogr_api.h presence... yes
checking for ogr_api.h... yes
checking cpl_conv.h usability... yes
checking cpl_conv.h presence... yes
checking for cpl_conv.h... yes
checking for GDALAllRegister in -lgdal... no
configure: error: could not find gdal
This is odd, because running nm against the libraries shows that the symbol is there:
vagrant at vagrant-64:~/postgis-2.0.0beta3$ nm --dynamic /usr/lib/libgdal1.7.0.so | grep GDALAllRegister
000000000021a820 T GDALAllRegister
Don't know if this is a bug in the latest beta, or a problem with Ubuntu's GDAL 1.7.0 libraries. Any advice would be appreciated.
-Charlie
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120314/3d524d98/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120314/3d524d98/attachment.png>
