[postgis-users] View PostGIS raster in mapserver
Salvatore Larosa
lrssvtml at gmail.com
Sat Mar 17 04:41:29 PDT 2012
you might you try:
SELECT ST_SummaryStats(rast) FROM table
and paste the result here!
then, add this to your mapfile in LAYER block:
CONFIG MS_ERRORFILE "stderr"
DEBUG 10
run shp2img and paste the output here!
to see if it's an error postgis or mapserver!
I had the same problem and I solved it by adding
PROCESSING "RESAMPLE=NEAREST"
in LAYER block!
Regards
-SL
Il giorno sab, 17/03/2012 alle 03.40 -0700, Hemin ha scritto:
> Hi,
> I try to use PostGIS 2.0 to convert a PostGIS geometry (table) to PostGIS
> raster and view the raster via Mapserver.
> I use:
> a. postgis version
> "POSTGIS="2.0.0alpha3" GEOS="3.3.3dev-CAPI-1.7.3" PROJ="Rel. 4.6.1, 21
> August 2008" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
> USE_STATS"
> b. Mapserver and GDAL version ( from MS4W v3.0.4)
> MapServer CGI 6.0.2
> MapScript 6.0.2 (CSharp, Java, PHP, Python)
> GDAL/OGR 1.9.0 and Utilities
> Steps:
> 1. create raster from pg table:
> create table raster.kommune_r as (SELECT
> ST_AsRaster((SELECT st_Union(wkb_geometry) FROM vector.kommune),
> 200,200,ARRAY['8BUI','8BUI', '8BUI'], ARRAY[100,100,100],
> ARRAY[50,50,50],704943, 6166793, 0, 0,false)
> as rast, 1 as gid );
> 2. update srid (I noticed that the raster has no srid):
> update raster.kommune_r set rast = st_setsrid(rast, 25832);
> 3. define a Mapserver layer:
> LAYER
> NAME kommune_r
> TYPE raster
> STATUS ON
> DATA "PG:host='localhost' port='5432' dbname='hto' user='hto'
> schema='raster' table='kommune_r' mode='2'"
> class
> name kommune_r
> style
> color 0 255 0
> end
> end
> PROJECTION
> "init=epsg:25832"
> END
> END
> The result is an empty *.png file.
> Du you have an idea about what is missing?
> Thanks in advance.
> Hemin
> View this message in context: http://postgis.17.n6.nabble.com/View-PostGIS-raster-in-mapserver-tp4627669p4627669.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
