[postgis-users] View PostGIS raster in mapserver
Hemin hemin.tofiq at gmail.com
Sat Mar 17 03:40:54 PDT 2012
I try to use PostGIS 2.0 to convert a PostGIS geometry (a table) to PostGIS
raster and view the raster via Mapserver.
I use:
a. postgis version
"POSTGIS="2.0.0alpha3" GEOS="3.3.3dev-CAPI-1.7.3" PROJ="Rel. 4.6.1, 21
August 2008" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
USE_STATS"
b. Mapserver and GDAL version ( from MS4W  v3.0.4)
MapServer CGI 6.0.2
MapScript 6.0.2 (CSharp, Java, PHP, Python)
GDAL/OGR 1.9.0 and Utilities
Steps:
1. create raster from pg table:
create table raster.kommune_r as (SELECT
ST_AsRaster((SELECT st_Union(wkb_geometry) FROM vector.kommune),
200,200,ARRAY['8BUI','8BUI', '8BUI'], ARRAY[100,100,100],
ARRAY[50,50,50],704943, 6166793, 0, 0,false)
as rast, 1 as gid );
2. update srid (I noticed that the raster has no srid):
update raster.kommune_r set rast = st_setsrid(rast, 25832);
3.  define a Mapserver layer:
   LAYER
      NAME kommune_r
      TYPE raster
      STATUS ON
      DATA "PG:host='localhost' port='5432' dbname='hto' user='hto'
schema='raster' table='kommune_r' mode='2'"
      class
        name kommune_r
        style
          color 0 255 0
        end
      end
      PROJECTION
       "init=epsg:25832"
      END
  END
The result is an empty *.png file.
Du you have an idea about what is missing?
Thanks in advance.
Hemin
View this message in context: http://postgis.17.n6.nabble.com/View-PostGIS-raster-in-mapserver-tp4627669p4627669.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
