[postgis-users] PostGIS 2.0 instalation problem
Piotr Pachół
piotrpachol at gmail.com
Sun Mar 18 15:13:41 PDT 2012
W dniu 2012-03-16 18:13, Bborie Park pisze:
> On 03/16/2012 04:45 AM, Piotr Pachół wrote:
>> Hello,
>> I try to install PostGIS 2.0 on Windows XP using script file
>> makepostgisdb_using_extensions.bat
>> During executing of line: "%PGBIN%\psql" -d "%THEDB%" -c "CREATE
>> EXTENSION
>> postgis;"
>> I received error: can't load library "C:/Program
>> Files/PostgreSQL/9.1/lib/postgis-2.0.dll": unknown error 126
>> I checked above path - file postgis-2.0.dll is that catalog.
>> What should I do?
> Piotr,
> The problem lies with the first xcopy in the batch file. Simplest
> thing to do is to turn off the PostgreSQL server and copy the contents
> of bin/*.* from the PostGIS zip archive to C:/Program
> Files/PostgreSQL/9.1/bin. Turn the PostgreSQL server back on and then
> run the psql scripts.
> -bborie
I followed steps you had mentioned but I still received the same error 126.
Is it possible to do instalation another way on Windows ?
Piotr
