[postgis-users] View PostGIS raster in mapserver
Salvatore Larosa
lrssvtml at gmail.com
Mon Mar 19 15:29:14 PDT 2012
Il giorno lun, 19/03/2012 alle 15.10 -0700, Hemin Tofiq ha scritto:
> path contains:
> C:\..\ms4w\tools;C:\..\ms4w\proj\bin;C:\ms4w\proj;C:\ms4w\Apache\cgi-bin
> but shp2img:
> shp2img -m C:\..\itasca.map -o C:\temp\shp2img.png -l kommune_r
> returns:
> msProcessProjection(): Projection library error. Permission denied
> msFreeMap(): freeing map at 00721FC8.
You should also set the path to the libraries.
Run setenv.bat and check that the PATH 'PROJ_LIB' is correct.
Regards
-SL
