[postgis-users] ST_Buffer + grid problem
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Thu Mar 22 07:16:32 PDT 2012
What I mean is to replace:
SELECT ST_AsRaster(ST_Extent(way_geom)::geometry, 0.000036, 0.000036) rast FROM buffers  where osm_id = 94695311
by something like:
SELECT ST_AsRaster(ST_GeomFromText('POLYGON((11.1539754732244 55.5772503545236,11.1540114732244 55.5772503545236,11.1540114732244 55.5772863545236,11.1539754732244 55.5772863545236,11.1539754732244 55.5772503545236))'), 0.000036, 0.000036)
with one of the geometry reproducing the bug so we don't need your dataset to test and reproduce.
Pierre
> -----Original Message-----
> From: manohar.kaul at gmail.com [mailto:manohar.kaul at gmail.com] On Behalf
> Of Ed Linde
> Sent: Thursday, March 22, 2012 9:59 AM
> To: Pierre Racine
> Cc: PostGIS Users Discussion; Bborie Park (bkpark at ucdavis.edu)
> Subject: Re: [postgis-users] ST_Buffer + grid problem
> sure. Did you mean ST_GeomfromText or show it as text?
> SELECT ST_GeomfromText ((gvxy).geom), ((gvxy).x - 1) * rwidth + (gvxy).y gridid
> FROM (SELECT ST_PixelAsPolygons(rast) gvxy, ST_Width(rast) rwidth
>             FROM (SELECT ST_AsRaster(ST_Extent(way_geom)::geometry, 0.000036,
> 0.000036) rast
>                          FROM buffers
>                         ) foo1
>            ) foo2;
> ERROR:  parse error - invalid geometry
> HINT:  "010300000001000000050000005" <-- parse error at position 27 within
> geometry
> ********** Error **********
> SQL state: XX000
> Hint: "010300000001000000050000005" <-- parse error at position 27 within
> geometry
> On Thu, Mar 22, 2012 at 2:53 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
> 	I guess this is related to a GDAL problem where you cannot create a
> raster using ST_AsRaster with pixel size smaller than 1. Was this fixed Bborie?
> 	Ed could you reduce the list of geometries passed to ST_Extent to one
> and write it as ST_GeomfromText so we can debug this more easily?
> 	Pierre
> On Behalf
> 	> Of Ed Linde
> 	> Sent: Thursday, March 22, 2012 9:45 AM
> 	> To: Pierre Racine
> 	> Hi Pierre,
> 	> So I am trying to have a 4meter by 4meter cell and I converted
> 4meters to
> 	> degrees, because I think ST_Extent will compute it in degrees as my
> geometry is
> 	> in srid 4326. But I get this GDAL error which I have no clue what it
> means. Any
> 	> ideas how I can fix it? Also I noticed that if I set it to 1.0, 1.0 I get
> 	> 21 rows but the gridid isn't continuous either (which is weird).
> 	> CREATE TABLE vectorgrid AS
> 	> SELECT (gvxy).geom, ((gvxy).x - 1) * rwidth + (gvxy).y gridid FROM
> (SELECT
> 0.000036,
> 	> 0.000036) rast
> 	>                          FROM buffers
> 	>                         ) foo1
> 	>            ) foo2;
> 	> ERROR:  rt_raster_gdal_rasterize: Unable to add band to GDALDataset
> SQL state:
> 	> XX000
> 	> On Thu, Mar 22, 2012 at 2:13 PM, Pierre Racine
> 	> wrote:
> 	>       You can control how the grid is aligned by using more ST_AsRaster
> 	> parameters. See:
> 	>       http://postgis.refractions.net/documentation/manual-
> 	> svn/RT_ST_AsRaster.html
> 	>       If you want it to align on your point, just align it on your points...
> 	>       Pierre
> 	> On Behalf
> 	>       > Of Ed Linde
> 	>       > Sent: Thursday, March 22, 2012 9:05 AM
> 	>       > To: PostGIS Users Discussion
> 	>       > Cc: Pierre Racine
> 	>       > Hi Pierre,
> 	>       > Thanks for the grid idea last night. I have a problem though, I
> want to
> 	> have a 4m
> 	>       > by 4m cell sized grid over my buffer geometries which are in SRID
> 	> 4326. And
> 	>       > then I have another data set of 2D points which are also in SRID
> 	> 4326...
> 	>       > wondering how I can figure out from just a given (lat,long) which
> cell
> 	> ID in the
> 	>       > buffer grid it would belong to? I am thinking that I might run into
> 	> "alignment
> 	>       > issues" because shouldn't the extent of the grid be exactly the
> same
> 	> on the 2D
> 	>       > point cloud as well, so that the grid cell IDs will match? Unless I
> am
> 	> missing
> 	>       > something here?
> 	>       > Cheers,
> 	>       > Ed
> 	>       > On Wed, Mar 21, 2012 at 8:46 PM, Pierre Racine
> 	>       > wrote:
> 	>       >       > I am not sure if this is possible, but I have computed (using
> 	> ST_Buffer)
> 	>       > a sort of
> 	>       >       > buffer around several LINESTRINGs. Now I would like to lay
> some
> 	> sort
> 	>       > of grid of
> 	>       >       > say 1m^2 cell size on top of this collection of geometries
> and
> 	> then
> 	>       > compute the
> 	>       >       > intersection... so in the end I would like to for example,
> know
> 	> that grid
> 	>       > cell ID = 1
> 	>       >       > intersects with buffers 1 and 10, grid cell 2 intersects with
> buffers
> 	> 7, 10
> 	>       > etc..
> 	>       >       > Is there a simple way of doing this in postgis? Maybe
> someone
> 	> could
> 	>       > point me to
> 	>       >       > some documentation of how I can generate such a grid in
> postgis
> 	> and
> 	>       > maybe
> 	>       >       > then I can use just ST_Intersect once I have these two
> 	> geometries?
> 	>       >       With the raster type you can now easily create a vector grid
> like
> 	> this:
> 	> rwidth
> 	>       >                   FROM (SELECT
> ST_AsRaster(ST_Extent(geom)::geometry,
> 	> 1.0,
> 	>       > 1.0) rast
> 	>       >                                FROM yourbuffertable
> 	>       >                               ) foo1
> 	>       >                  ) foo2;
> 	>       >       Make sure a spatial index exist on both tables:
> 	>       >       CREATE INDEX yourbuffertable_geom_idx  ON
> yourbuffertable
> 	> USING
> 	>       > gist  (geom);
> 	>       >       CREATE INDEX vectorgrid _geom_idx  ON vectorgrid USING
> gist
> 	>       > (geom);
> 	>       >       You can then perform a normal intersect query:
> 	>       >       CREATE TABLE interresult AS
> 	>       >       SELECT b.bufferid, g.gridid, ST_Intersection(g.geom, b.geom)
> 	> geom
> 	>       >       FROM vectorgrid g, yourbuffertable b
> 	>       >       WHERE ST_Intersects(g.geom, b.geom);
> 	>       >       Pierre
> 	>       >       _______________________________________________
> 	>       >       postgis-users mailing list
> 	>       >       postgis-users at postgis.refractions.net
> 	>       >       http://postgis.refractions.net/mailman/listinfo/postgis-users
