[postgis-users] ST_Buffer + grid problem
Ed Linde edolinde at gmail.com
Thu Mar 22 07:23:04 PDT 2012
Yeah only problem being that I don't know which geometry is the one that
fails... its a table with 300K geometries.
Have never written any PgSQL, so this I guess would require a loop to check
which OSM ID its failing on. Unless
you got a good idea to pin-point this error?
On Thu, Mar 22, 2012 at 3:16 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> What I mean is to replace:
> SELECT ST_AsRaster(ST_Extent(way_geom)::geometry, 0.000036, 0.000036) rast
> FROM buffers  where osm_id = 94695311
> by something like:
> SELECT ST_AsRaster(ST_GeomFromText('POLYGON((11.1539754732244
> 55.5772503545236,11.1540114732244 55.5772503545236,11.1540114732244
> 55.5772863545236,11.1539754732244 55.5772863545236,11.1539754732244
> 55.5772503545236))'), 0.000036, 0.000036)
> with one of the geometry reproducing the bug so we don't need your dataset
> to test and reproduce.
> Pierre
> > -----Original Message-----
> > From: manohar.kaul at gmail.com [mailto:manohar.kaul at gmail.com] On Behalf
> > Of Ed Linde
> > Sent: Thursday, March 22, 2012 9:59 AM
> > To: Pierre Racine
> > Cc: PostGIS Users Discussion; Bborie Park (bkpark at ucdavis.edu)
> > Subject: Re: [postgis-users] ST_Buffer + grid problem
> > sure. Did you mean ST_GeomfromText or show it as text?
> > SELECT ST_GeomfromText ((gvxy).geom), ((gvxy).x - 1) * rwidth + (gvxy).y
> gridid
> > FROM (SELECT ST_PixelAsPolygons(rast) gvxy, ST_Width(rast) rwidth
> >             FROM (SELECT ST_AsRaster(ST_Extent(way_geom)::geometry,
> 0.000036,
> > 0.000036) rast
> >                          FROM buffers
> >                         ) foo1
> >            ) foo2;
> > ERROR:  parse error - invalid geometry
> > HINT:  "010300000001000000050000005" <-- parse error at position 27
> within
> > geometry
> > ********** Error **********
> > SQL state: XX000
> > Hint: "010300000001000000050000005" <-- parse error at position 27 within
> > geometry
> > On Thu, Mar 22, 2012 at 2:53 PM, Pierre Racine <
> > wrote:
> >       I guess this is related to a GDAL problem where you cannot create a
> > raster using ST_AsRaster with pixel size smaller than 1. Was this fixed
> Bborie?
> >       Ed could you reduce the list of geometries passed to ST_Extent to
> one
> > and write it as ST_GeomfromText so we can debug this more easily?
> >       Pierre
> > On Behalf
> >       > Of Ed Linde
> >       > Sent: Thursday, March 22, 2012 9:45 AM
> >       > To: Pierre Racine
> >       > Hi Pierre,
> >       > So I am trying to have a 4meter by 4meter cell and I converted
> > 4meters to
> >       > degrees, because I think ST_Extent will compute it in degrees as
> my
> > geometry is
> >       > in srid 4326. But I get this GDAL error which I have no clue
> what it
> > means. Any
> >       > ideas how I can fix it? Also I noticed that if I set it to 1.0,
> 1.0 I get
> >       > 21 rows but the gridid isn't continuous either (which is weird).
> >       > CREATE TABLE vectorgrid AS
> >       > SELECT (gvxy).geom, ((gvxy).x - 1) * rwidth + (gvxy).y gridid
> FROM
> > (SELECT
> >       >             FROM (SELECT
> > 0.000036,
> >       > 0.000036) rast
> >       >                          FROM buffers
> >       >                         ) foo1
> >       >            ) foo2;
> >       > ERROR:  rt_raster_gdal_rasterize: Unable to add band to
> GDALDataset
> GDALDataset
> > SQL state:
> >       > XX000
> >       > On Thu, Mar 22, 2012 at 2:13 PM, Pierre Racine
> >       > wrote:
> >       >       You can control how the grid is aligned by using more
> ST_AsRaster
> >       > parameters. See:
> >       >       http://postgis.refractions.net/documentation/manual-
> >       > svn/RT_ST_AsRaster.html
> >       >       If you want it to align on your point, just align it on
> your points...
> >       >       Pierre
> >       > On Behalf
> >       >       > Of Ed Linde
> >       >       > Sent: Thursday, March 22, 2012 9:05 AM
> >       >       > To: PostGIS Users Discussion
> >       >       > Cc: Pierre Racine
> >       >       > Hi Pierre,
> >       >       > Thanks for the grid idea last night. I have a problem
> though, I
> > want to
> >       > have a 4m
> >       >       > by 4m cell sized grid over my buffer geometries which
> are in SRID
> >       > 4326. And
> >       >       > then I have another data set of 2D points which are also
> in SRID
> >       > 4326...
> >       >       > wondering how I can figure out from just a given
> (lat,long) which
> > cell
> >       > ID in the
> >       >       > buffer grid it would belong to? I am thinking that I
> might run into
> >       > "alignment
> >       >       > issues" because shouldn't the extent of the grid be
> exactly the
> > same
> >       > on the 2D
> >       >       > point cloud as well, so that the grid cell IDs will
> match? Unless I
> > am
> >       > missing
> >       >       > something here?
> >       >       > Cheers,
> >       >       > Ed
> >       >       > On Wed, Mar 21, 2012 at 8:46 PM, Pierre Racine
> >       >       > wrote:
> >       >       >       > I am not sure if this is possible, but I have
> computed (using
> >       > ST_Buffer)
> >       >       > a sort of
> >       >       >       > buffer around several LINESTRINGs. Now I would
> like to lay
> > some
> >       > sort
> >       >       > of grid of
> >       >       >       > say 1m^2 cell size on top of this collection of
> geometries
> > and
> >       > then
> >       >       > compute the
> >       >       >       > intersection... so in the end I would like to
> for example,
> > know
> >       > that grid
> >       >       > cell ID = 1
> >       >       >       > intersects with buffers 1 and 10, grid cell 2
> intersects with
> > buffers
> >       > 7, 10
> >       >       > etc..
> >       >       >       > Is there a simple way of doing this in postgis?
> Maybe
> > someone
> >       > could
> >       >       > point me to
> >       >       >       > some documentation of how I can generate such a
> grid in
> > postgis
> >       > and
> >       >       > maybe
> >       >       >       > then I can use just ST_Intersect once I have
> these two
> >       > geometries?
> >       >       >       With the raster type you can now easily create a
> vector grid
> > like
> >       > this:
> (gvxy).y gridid
> ST_Width(rast)
> >       > rwidth
> >       >       >                   FROM (SELECT
> > ST_AsRaster(ST_Extent(geom)::geometry,
> >       > 1.0,
> >       >       > 1.0) rast
> >       >       >                                FROM yourbuffertable
> >       >       >                               ) foo1
> >       >       >                  ) foo2;
> >       >       >       Make sure a spatial index exist on both tables:
> >       >       >       CREATE INDEX yourbuffertable_geom_idx  ON
> > yourbuffertable
> >       > USING
> >       >       > gist  (geom);
> >       >       >       CREATE INDEX vectorgrid _geom_idx  ON vectorgrid
> USING
> > gist
> >       >       > (geom);
> >       >       >       You can then perform a normal intersect query:
> >       >       >       CREATE TABLE interresult AS
> >       >       >       SELECT b.bufferid, g.gridid,
> ST_Intersection(g.geom, b.geom)
> >       > geom
> >       >       >       FROM vectorgrid g, yourbuffertable b
> >       >       >       WHERE ST_Intersects(g.geom, b.geom);
> >       >       >       Pierre
> >       >       >       _______________________________________________
> >       >       >       postgis-users mailing list
> >       >       >       postgis-users at postgis.refractions.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120322/99daa9d7/attachment.html>
