[postgis-users] ST_Buffer + grid problem
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Thu Mar 22 09:09:14 PDT 2012
Hum... That works here. Could you do:
SELECT PostGIS_Full_Version();
> -----Original Message-----
> From: manohar.kaul at gmail.com [mailto:manohar.kaul at gmail.com] On Behalf
> Of Ed Linde
> Sent: Thursday, March 22, 2012 11:45 AM
> To: Pierre Racine
> Cc: PostGIS Users Discussion; Bborie Park (bkpark at ucdavis.edu)
> Subject: Re: [postgis-users] ST_Buffer + grid problem
> Hi Pierre,
> Here goes the error reproduced (hope it helps): If this cannot be resolved is
> there another work around? I am a bit under the pump here to get this grid done
> So the SRID = 4326 and this is the polygon/bounding box for entire road network
> of OSM.
> select ST_AsRaster( ST_GeomFromText('POLYGON((8.07734039737749
> 54.4984986588244,8.07734039737749 57.7505109647578,15.1919565742587
> 57.7505109647578,15.1919565742587 54.4984986588244,8.07734039737749
> 54.4984986588244))'), 0.000036, 0.000036);
> ERROR: rt_raster_gdal_rasterize: Unable to add band to GDALDataset
> ********** Error **********
> SQL state: XX000
> On Thu, Mar 22, 2012 at 4:00 PM, Ed Linde <edolinde at gmail.com> wrote:
> I tried a few roads at random and it doesn't reproduce that error,
> though I am a bit suspicious about the actual
> query. This part in particular
> (SELECT ST_AsRaster(ST_Extent(way_geom)::geometry, 0.000036,
> > 0.000036) rast
> > FROM buffers
> > ) foo1
> Are we saying that we want to compute the extent of each and every
> geometry in my table? Or should we not
> be getting the maximum extents for ALL the geometries?
> So when I say something like "FROM buffers where osm_id in (... list of
> 10 IDs)... " this query runs forever!
> Eventhough checking them one by one returns with results immediately.
> So I am not entirely sure how to do this or how I can reproduce this bug
> to help you guys.
> Any suggestions?
> On Thu, Mar 22, 2012 at 3:23 PM, Ed Linde <edolinde at gmail.com>
> wrote:
> Yeah only problem being that I don't know which geometry is
> the one that fails... its a table with 300K geometries.
> Have never written any PgSQL, so this I guess would require a
> loop to check which OSM ID its failing on. Unless
> you got a good idea to pin-point this error?
> On Thu, Mar 22, 2012 at 3:16 PM, Pierre Racine
> <Pierre.Racine at sbf.ulaval.ca> wrote:
> What I mean is to replace:
> 0.000036, 0.000036) rast FROM buffers where osm_id = 94695311
> by something like:
> SELECT
> ST_AsRaster(ST_GeomFromText('POLYGON((11.1539754732244
> 55.5772503545236,11.1540114732244 55.5772503545236,11.1540114732244
> 55.5772863545236,11.1539754732244 55.5772863545236,11.1539754732244
> 55.5772503545236))'), 0.000036, 0.000036)
> with one of the geometry reproducing the bug so we
> don't need your dataset to test and reproduce.
> Pierre
> > Of Ed Linde
> > Sent: Thursday, March 22, 2012 9:59 AM
> > To: Pierre Racine
> > sure. Did you mean ST_GeomfromText or show it as
> text?
> > SELECT ST_GeomfromText ((gvxy).geom), ((gvxy).x -
> 1) * rwidth + (gvxy).y gridid
> > FROM (SELECT ST_PixelAsPolygons(rast) gvxy,
> ST_Width(rast) rwidth
> > FROM (SELECT
> > 0.000036) rast
> > FROM buffers
> > ) foo1
> > ) foo2;
> > ERROR: parse error - invalid geometry
> > HINT: "010300000001000000050000005" <-- parse
> error at position 27 within
> > geometry
> > SQL state: XX000
> > Hint: "010300000001000000050000005" <-- parse
> > geometry
> > On Thu, Mar 22, 2012 at 2:53 PM, Pierre Racine
> > wrote:
> > I guess this is related to a GDAL problem where
> you cannot create a
> > raster using ST_AsRaster with pixel size smaller than
> 1. Was this fixed Bborie?
> > Ed could you reduce the list of geometries passed
> to ST_Extent to one
> > and write it as ST_GeomfromText so we can debug
> this more easily?
> > Pierre
> > On Behalf
> > > Of Ed Linde
> > > Sent: Thursday, March 22, 2012 9:45 AM
> > > To: Pierre Racine
> problem
> > > Hi Pierre,
> > > So I am trying to have a 4meter by 4meter cell
> and I converted
> > 4meters to
> > > degrees, because I think ST_Extent will compute
> it in degrees as my
> > geometry is
> > > in srid 4326. But I get this GDAL error which I
> have no clue what it
> > means. Any
> > > ideas how I can fix it? Also I noticed that if I set it
> to 1.0, 1.0 I get
> > > 21 rows but the gridid isn't continuous either
> (which is weird).
> > > CREATE TABLE vectorgrid AS
> > > SELECT (gvxy).geom, ((gvxy).x - 1) * rwidth +
> (gvxy).y gridid FROM
> > (SELECT
> > > ST_PixelAsPolygons(rast) gvxy, ST_Width(rast)
> rwidth
> > > FROM (SELECT
> > 0.000036,
> > > 0.000036) rast
> > > FROM buffers
> > > ) foo1
> > > ) foo2;
> band to GDALDataset
> band to GDALDataset
> > SQL state:
> > > XX000
> > > On Thu, Mar 22, 2012 at 2:13 PM, Pierre Racine
> > > wrote:
> > > You can control how the grid is aligned by
> using more ST_AsRaster
> > > parameters. See:
> http://postgis.refractions.net/documentation/manual-
> > > svn/RT_ST_AsRaster.html
> > > If you want it to align on your point, just align
> it on your points...
> > > Pierre
> > > On Behalf
> > > > Of Ed Linde
> > > > Sent: Thursday, March 22, 2012 9:05 AM
> > > > To: PostGIS Users Discussion
> > > > Cc: Pierre Racine
> problem
> > > > Hi Pierre,
> > > > Thanks for the grid idea last night. I have a
> problem though, I
> > want to
> > > have a 4m
> > > > by 4m cell sized grid over my buffer
> geometries which are in SRID
> > > 4326. And
> > > > then I have another data set of 2D points
> which are also in SRID
> > > 4326...
> > > > wondering how I can figure out from just a
> given (lat,long) which
> > cell
> > > ID in the
> > > > buffer grid it would belong to? I am thinking
> that I might run into
> > > "alignment
> > > > issues" because shouldn't the extent of the
> grid be exactly the
> > same
> > > on the 2D
> > > > point cloud as well, so that the grid cell IDs
> will match? Unless I
> > am
> > > missing
> > > > something here?
> > > > Cheers,
> > > > Ed
> > > > On Wed, Mar 21, 2012 at 8:46 PM, Pierre
> Racine
> > > > wrote:
> > > > > I am not sure if this is possible, but I
> have computed (using
> > > ST_Buffer)
> > > > a sort of
> > > > > buffer around several LINESTRINGs.
> Now I would like to lay
> > some
> > > sort
> > > > of grid of
> > > > > say 1m^2 cell size on top of this
> collection of geometries
> > and
> > > then
> > > > compute the
> > > > > intersection... so in the end I would
> like to for example,
> > know
> > > that grid
> > > > cell ID = 1
> > > > > intersects with buffers 1 and 10, grid
> cell 2 intersects with
> > buffers
> > > 7, 10
> > > > etc..
> > > > > Is there a simple way of doing this in
> postgis? Maybe
> > someone
> > > could
> > > > point me to
> > > > > some documentation of how I can
> generate such a grid in
> > postgis
> > > and
> > > > maybe
> > > > > then I can use just ST_Intersect once I
> have these two
> > > geometries?
> > > > With the raster type you can now easily
> create a vector grid
> > like
> > > this:
> > > rwidth
> > > > FROM (SELECT
> > ST_AsRaster(ST_Extent(geom)::geometry,
> > > 1.0,
> > > > 1.0) rast
> > > > FROM yourbuffertable
> > > > ) foo1
> > > > ) foo2;
> > > > Make sure a spatial index exist on both
> tables:
> > > > CREATE INDEX
> yourbuffertable_geom_idx ON
> > yourbuffertable
> > > USING
> > > > gist (geom);
> > > > CREATE INDEX vectorgrid _geom_idx
> ON vectorgrid USING
> > gist
> > > > (geom);
> > > > You can then perform a normal intersect
> query:
> > > > CREATE TABLE interresult AS
> > > > SELECT b.bufferid, g.gridid,
> ST_Intersection(g.geom, b.geom)
> > > geom
> > > > FROM vectorgrid g, yourbuffertable b
> > > > WHERE ST_Intersects(g.geom, b.geom);
> > > > Pierre
> > > > postgis-users mailing list
> > > > postgis-users at postgis.refractions.net
