[postgis-users] ST_Buffer + grid problem
Ed Linde edolinde at gmail.com
Thu Mar 22 09:11:17 PDT 2012
"POSTGIS="2.0.0alpha7SVN" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.7.3, released 2010/11/10" LIBXML="2.7.8"
USE_STATS"
I used this because I remember I wanted GEOS/GDAL support and while
installing it there was some easy option of getting raster support. I think
someone suggested
using Postgis 2.0!
On Thu, Mar 22, 2012 at 5:09 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> Hum... That works here. Could you do:
> SELECT PostGIS_Full_Version();
> > -----Original Message-----
> > From: manohar.kaul at gmail.com [mailto:manohar.kaul at gmail.com] On Behalf
> > Of Ed Linde
> > Sent: Thursday, March 22, 2012 11:45 AM
> > To: Pierre Racine
> > Cc: PostGIS Users Discussion; Bborie Park (bkpark at ucdavis.edu)
> > Subject: Re: [postgis-users] ST_Buffer + grid problem
> > Hi Pierre,
> > Here goes the error reproduced (hope it helps): If this cannot be
> resolved is
> > there another work around? I am a bit under the pump here to get this
> grid done
> > So the SRID = 4326 and this is the polygon/bounding box for entire road
> network
> > of OSM.
> > select ST_AsRaster( ST_GeomFromText('POLYGON((8.07734039737749
> > 54.4984986588244,8.07734039737749 57.7505109647578,15.1919565742587
> > 57.7505109647578,15.1919565742587 54.4984986588244,8.07734039737749
> > 54.4984986588244))'), 0.000036, 0.000036);
> > ERROR:  rt_raster_gdal_rasterize: Unable to add band to GDALDataset
> > ********** Error **********
> > SQL state: XX000
> > On Thu, Mar 22, 2012 at 4:00 PM, Ed Linde <edolinde at gmail.com> wrote:
> >       I tried a few roads at random and it doesn't reproduce that error,
> > though I am a bit suspicious about the actual
> >       query. This part in particular
> >       (SELECT ST_AsRaster(ST_Extent(way_geom)::geometry, 0.000036,
> >       > 0.000036) rast
> >       >                          FROM buffers
> >       >                         ) foo1
> >       Are we saying that we want to compute the extent of each and every
> > geometry in my table? Or should we not
> >       be getting the maximum extents for ALL the geometries?
> >       So when I say something like "FROM buffers where osm_id in (...
> list of
> > 10 IDs)... " this query runs forever!
> >       Eventhough checking them one by one returns with results
> immediately.
> >       So I am not entirely sure how to do this or how I can reproduce
> this bug
> > to help you guys.
> >       Any suggestions?
> >       On Thu, Mar 22, 2012 at 3:23 PM, Ed Linde <edolinde at gmail.com>
> > wrote:
> >               Yeah only problem being that I don't know which geometry is
> > the one that fails... its a table with 300K geometries.
> >               Have never written any PgSQL, so this I guess would
> require a
> > loop to check which OSM ID its failing on. Unless
> >               you got a good idea to pin-point this error?
> >               On Thu, Mar 22, 2012 at 3:16 PM, Pierre Racine
> > <Pierre.Racine at sbf.ulaval.ca> wrote:
> >                       What I mean is to replace:
> > 0.000036, 0.000036) rast FROM buffers  where osm_id = 94695311
> >                       by something like:
> >                       SELECT
> > ST_AsRaster(ST_GeomFromText('POLYGON((11.1539754732244
> > 55.5772503545236,11.1540114732244 55.5772503545236,11.1540114732244
> > 55.5772863545236,11.1539754732244 55.5772863545236,11.1539754732244
> > 55.5772503545236))'), 0.000036, 0.000036)
> >                       with one of the geometry reproducing the bug so we
> > don't need your dataset to test and reproduce.
> >                       Pierre
> >                       > Of Ed Linde
> >                       > Sent: Thursday, March 22, 2012 9:59 AM
> >                       > To: Pierre Racine
> problem
> >                       > sure. Did you mean ST_GeomfromText or show it as
> > text?
> >                       > SELECT ST_GeomfromText ((gvxy).geom), ((gvxy).x -
> > 1) * rwidth + (gvxy).y gridid
> >                       > FROM (SELECT ST_PixelAsPolygons(rast) gvxy,
> > ST_Width(rast) rwidth
> >                       >             FROM (SELECT
> >                       > 0.000036) rast
> >                       >                          FROM buffers
> >                       >                         ) foo1
> >                       >            ) foo2;
> >                       > ERROR:  parse error - invalid geometry
> >                       > HINT:  "010300000001000000050000005" <-- parse
> > error at position 27 within
> >                       > geometry
> >                       > SQL state: XX000
> >                       > Hint: "010300000001000000050000005" <-- parse
> >                       > geometry
> >                       > On Thu, Mar 22, 2012 at 2:53 PM, Pierre Racine
> >                       > wrote:
> >                       >       I guess this is related to a GDAL problem
> where
> > you cannot create a
> >                       > raster using ST_AsRaster with pixel size smaller
> than
> > 1. Was this fixed Bborie?
> >                       >       Ed could you reduce the list of geometries
> passed
> > to ST_Extent to one
> >                       > and write it as ST_GeomfromText so we can debug
> > this more easily?
> >                       >       Pierre
> >                       > On Behalf
> >                       >       > Of Ed Linde
> >                       >       > Sent: Thursday, March 22, 2012 9:45 AM
> >                       >       > To: Pierre Racine
> grid
> > problem
> >                       >       > Hi Pierre,
> >                       >       > So I am trying to have a 4meter by
> 4meter cell
> > and I converted
> >                       > 4meters to
> >                       >       > degrees, because I think ST_Extent will
> compute
> > it in degrees as my
> >                       > geometry is
> >                       >       > in srid 4326. But I get this GDAL error
> which I
> > have no clue what it
> >                       > means. Any
> >                       >       > ideas how I can fix it? Also I noticed
> that if I set it
> > to 1.0, 1.0 I get
> >                       >       > 21 rows but the gridid isn't continuous
> either
> > (which is weird).
> >                       >       > CREATE TABLE vectorgrid AS
> >                       >       > SELECT (gvxy).geom, ((gvxy).x - 1) *
> rwidth +
> > (gvxy).y gridid FROM
> >                       > (SELECT
> ST_Width(rast)
> > rwidth
> >                       >       >             FROM (SELECT
> >                       > 0.000036,
> >                       >       > 0.000036) rast
> >                       >       >                          FROM buffers
> >                       >       >                         ) foo1
> >                       >       >            ) foo2;
> to add
> > band to GDALDataset
> to add
> > band to GDALDataset
> >                       > SQL state:
> >                       >       > XX000
> >                       >       > On Thu, Mar 22, 2012 at 2:13 PM, Pierre
> Racine
> >                       >       > wrote:
> >                       >       >       You can control how the grid is
> aligned by
> > using more ST_AsRaster
> >                       >       > parameters. See:
> > http://postgis.refractions.net/documentation/manual-
> >                       >       > svn/RT_ST_AsRaster.html
> >                       >       >       If you want it to align on your
> point, just align
> > it on your points...
> >                       >       >       Pierre
> >                       >       > On Behalf
> >                       >       >       > Of Ed Linde
> 9:05 AM
> >                       >       >       > To: PostGIS Users Discussion
> >                       >       >       > Cc: Pierre Racine
> ST_Buffer + grid
> > problem
> >                       >       >       > Hi Pierre,
> >                       >       >       > Thanks for the grid idea last
> night. I have a
> > problem though, I
> >                       > want to
> >                       >       > have a 4m
> >                       >       >       > by 4m cell sized grid over my
> buffer
> > geometries which are in SRID
> >                       >       > 4326. And
> >                       >       >       > then I have another data set of
> 2D points
> > which are also in SRID
> >                       >       > 4326...
> >                       >       >       > wondering how I can figure out
> from just a
> > given (lat,long) which
> >                       > cell
> >                       >       > ID in the
> >                       >       >       > buffer grid it would belong to?
> I am thinking
> > that I might run into
> >                       >       > "alignment
> >                       >       >       > issues" because shouldn't the
> extent of the
> > grid be exactly the
> >                       > same
> >                       >       > on the 2D
> >                       >       >       > point cloud as well, so that the
> grid cell IDs
> > will match? Unless I
> >                       > am
> >                       >       > missing
> >                       >       >       > something here?
> >                       >       >       > Cheers,
> >                       >       >       > Ed
> >                       >       >       > On Wed, Mar 21, 2012 at 8:46 PM,
> Pierre
> > Racine
> >                       >       >       > wrote:
> >                       >       >       >       > I am not sure if this is
> possible, but I
> > have computed (using
> >                       >       > ST_Buffer)
> >                       >       >       > a sort of
> >                       >       >       >       > buffer around several
> LINESTRINGs.
> > Now I would like to lay
> >                       > some
> >                       >       > sort
> >                       >       >       > of grid of
> >                       >       >       >       > say 1m^2 cell size on
> top of this
> > collection of geometries
> >                       > and
> >                       >       > then
> >                       >       >       > compute the
> >                       >       >       >       > intersection... so in
> the end I would
> > like to for example,
> >                       > know
> >                       >       > that grid
> >                       >       >       > cell ID = 1
> >                       >       >       >       > intersects with buffers
> 1 and 10, grid
> > cell 2 intersects with
> >                       > buffers
> >                       >       > 7, 10
> >                       >       >       > etc..
> >                       >       >       >       > Is there a simple way of
> doing this in
> > postgis? Maybe
> >                       > someone
> >                       >       > could
> >                       >       >       > point me to
> >                       >       >       >       > some documentation of
> how I can
> > generate such a grid in
> >                       > postgis
> >                       >       > and
> >                       >       >       > maybe
> >                       >       >       >       > then I can use just
> ST_Intersect once I
> > have these two
> >                       >       > geometries?
> >                       >       >       >       With the raster type you
> can now easily
> > create a vector grid
> >                       > like
> >                       >       > this:
> >                       >       >       >       SELECT (gvxy).geom,
> ((gvxy).x - 1) *
> >                       >       >       >       FROM (SELECT
> > gvxy, ST_Width(rast)
> >                       >       > rwidth
> >                       >       >       >                   FROM (SELECT
> >                       > ST_AsRaster(ST_Extent(geom)::geometry,
> >                       >       > 1.0,
> >                       >       >       > 1.0) rast
>  FROM yourbuffertable
> foo1
> >                       >       >       >                  ) foo2;
> >                       >       >       >       Make sure a spatial index
> exist on both
> > tables:
> >                       >       >       >       CREATE INDEX
> > yourbuffertable_geom_idx  ON
> >                       > yourbuffertable
> >                       >       > USING
> >                       >       >       > gist  (geom);
> >                       >       >       >       CREATE INDEX vectorgrid
> _geom_idx
> > ON vectorgrid USING
> >                       > gist
> >                       >       >       > (geom);
> >                       >       >       >       You can then perform a
> normal intersect
> > query:
> >                       >       >       >       CREATE TABLE interresult AS
> >                       >       >       >       SELECT b.bufferid,
> g.gridid,
> > ST_Intersection(g.geom, b.geom)
> >                       >       > geom
> >                       >       >       >       FROM vectorgrid g,
> yourbuffertable b
> >                       >       >       >       WHERE
> ST_Intersects(g.geom, b.geom);
> >                       >       >       >       Pierre
> >                       >       >       >       postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120322/559c1190/attachment.html>
