[postgis-users] ST_Buffer + grid problem
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Thu Mar 22 09:59:02 PDT 2012
What if you upgrade GDAL to 1.9?
> -----Original Message-----
> From: manohar.kaul at gmail.com [mailto:manohar.kaul at gmail.com] On Behalf
> Of Ed Linde
> Sent: Thursday, March 22, 2012 12:11 PM
> To: Pierre Racine
> Cc: PostGIS Users Discussion; Bborie Park (bkpark at ucdavis.edu)
> Subject: Re: [postgis-users] ST_Buffer + grid problem
> "POSTGIS="2.0.0alpha7SVN" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23
> September 2009" GDAL="GDAL 1.7.3, released 2010/11/10" LIBXML="2.7.8"
> USE_STATS"
> I used this because I remember I wanted GEOS/GDAL support and while installing
> it there was some easy option of getting raster support. I think someone
> suggested using Postgis 2.0!
> On Thu, Mar 22, 2012 at 5:09 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
>       Hum... That works here. Could you do:
>       SELECT PostGIS_Full_Version();
> On Behalf
>       > Of Ed Linde
>       > Sent: Thursday, March 22, 2012 11:45 AM
>       > To: Pierre Racine
>       > Hi Pierre,
>       > Here goes the error reproduced (hope it helps): If this cannot be
> resolved is
>       > there another work around? I am a bit under the pump here to get this
> grid done
>       > So the SRID = 4326 and this is the polygon/bounding box for entire
> road network
>       > of OSM.
>       > select ST_AsRaster(
> ST_GeomFromText('POLYGON((8.07734039737749
>       > 54.4984986588244,8.07734039737749
> 57.7505109647578,15.1919565742587
>       > 54.4984986588244))'), 0.000036, 0.000036);
>       > ERROR:  rt_raster_gdal_rasterize: Unable to add band to GDALDataset
>       > ********** Error **********
>       > SQL state: XX000
>       > On Thu, Mar 22, 2012 at 4:00 PM, Ed Linde <edolinde at gmail.com>
> wrote:
>       >       I tried a few roads at random and it doesn't reproduce that error,
>       > though I am a bit suspicious about the actual
>       >       query. This part in particular
>       >       (SELECT ST_AsRaster(ST_Extent(way_geom)::geometry, 0.000036,
>       >       > 0.000036) rast
>       >       >                          FROM buffers
>       >       >                         ) foo1
>       >       Are we saying that we want to compute the extent of each and
> every
>       > geometry in my table? Or should we not
>       >       be getting the maximum extents for ALL the geometries?
>       >       So when I say something like "FROM buffers where osm_id in (...
> list of
>       > 10 IDs)... " this query runs forever!
>       >       Eventhough checking them one by one returns with results
> immediately.
>       >       So I am not entirely sure how to do this or how I can reproduce this
> bug
>       > to help you guys.
>       >       Any suggestions?
>       >       On Thu, Mar 22, 2012 at 3:23 PM, Ed Linde <edolinde at gmail.com>
>       > wrote:
>       >               Yeah only problem being that I don't know which geometry is
>       > the one that fails... its a table with 300K geometries.
>       >               Have never written any PgSQL, so this I guess would require a
>       > loop to check which OSM ID its failing on. Unless
>       >               you got a good idea to pin-point this error?
>       >               On Thu, Mar 22, 2012 at 3:16 PM, Pierre Racine
>       > <Pierre.Racine at sbf.ulaval.ca> wrote:
>       >                       What I mean is to replace:
>       > 0.000036, 0.000036) rast FROM buffers  where osm_id = 94695311
>       >                       by something like:
>       >                       SELECT
>       > ST_AsRaster(ST_GeomFromText('POLYGON((11.1539754732244
>       > 55.5772503545236,11.1540114732244
>       > 55.5772863545236,11.1539754732244
>       > 55.5772503545236))'), 0.000036, 0.000036)
>       >                       with one of the geometry reproducing the bug so we
>       > don't need your dataset to test and reproduce.
>       >                       Pierre
>       >                       > Of Ed Linde
>       >                       > Sent: Thursday, March 22, 2012 9:59 AM
>       >                       > To: Pierre Racine
>       >                       > sure. Did you mean ST_GeomfromText or show it as
>       > text?
>       >                       > SELECT ST_GeomfromText ((gvxy).geom), ((gvxy).x -
>       > 1) * rwidth + (gvxy).y gridid
>       >                       > FROM (SELECT ST_PixelAsPolygons(rast) gvxy,
>       > ST_Width(rast) rwidth
>       >                       >             FROM (SELECT
>       >                       > 0.000036) rast
>       >                       >                          FROM buffers
>       >                       >                         ) foo1
>       >                       >            ) foo2;
>       >                       > ERROR:  parse error - invalid geometry
>       >                       > HINT:  "010300000001000000050000005" <-- parse
>       > error at position 27 within
>       >                       > geometry
>       >                       > SQL state: XX000
>       >                       > Hint: "010300000001000000050000005" <-- parse
>       >                       > geometry
>       >                       > On Thu, Mar 22, 2012 at 2:53 PM, Pierre Racine
>       >                       > wrote:
>       >                       >       I guess this is related to a GDAL problem where
>       > you cannot create a
>       >                       > raster using ST_AsRaster with pixel size smaller than
>       > 1. Was this fixed Bborie?
>       >                       >       Ed could you reduce the list of geometries passed
>       > to ST_Extent to one
>       >                       > and write it as ST_GeomfromText so we can debug
>       > this more easily?
>       >                       >       Pierre
>       >                       > On Behalf
>       >                       >       > Of Ed Linde
>       >                       >       > Sent: Thursday, March 22, 2012 9:45 AM
>       >                       >       > To: Pierre Racine
>       > problem
>       >                       >       > Hi Pierre,
>       >                       >       > So I am trying to have a 4meter by 4meter cell
>       > and I converted
>       >                       > 4meters to
>       >                       >       > degrees, because I think ST_Extent will compute
>       > it in degrees as my
>       >                       > geometry is
>       >                       >       > in srid 4326. But I get this GDAL error which I
>       > have no clue what it
>       >                       > means. Any
>       >                       >       > ideas how I can fix it? Also I noticed that if I set it
>       > to 1.0, 1.0 I get
>       >                       >       > 21 rows but the gridid isn't continuous either
>       > (which is weird).
>       >                       >       > CREATE TABLE vectorgrid AS
>       >                       >       > SELECT (gvxy).geom, ((gvxy).x - 1) * rwidth +
>       > (gvxy).y gridid FROM
>       >                       > (SELECT
>       >                       >       > ST_PixelAsPolygons(rast) gvxy, ST_Width(rast)
>       > rwidth
>       >                       >       >             FROM (SELECT
>       >                       > 0.000036,
>       >                       >       > 0.000036) rast
>       >                       >       >                          FROM buffers
>       >                       >       >                         ) foo1
>       >                       >       >            ) foo2;
>       > band to GDALDataset
>       > band to GDALDataset
>       >                       > SQL state:
>       >                       >       > XX000
>       >                       >       > On Thu, Mar 22, 2012 at 2:13 PM, Pierre Racine
>       >                       >       > wrote:
>       >                       >       >       You can control how the grid is aligned by
>       > using more ST_AsRaster
>       >                       >       > parameters. See:
>       > http://postgis.refractions.net/documentation/manual-
>       >                       >       > svn/RT_ST_AsRaster.html
>       >                       >       >       If you want it to align on your point, just align
>       > it on your points...
>       >                       >       >       Pierre
>       >                       >       > On Behalf
>       >                       >       >       > Of Ed Linde
>       >                       >       >       > Sent: Thursday, March 22, 2012 9:05 AM
>       >                       >       >       > To: PostGIS Users Discussion
>       >                       >       >       > Cc: Pierre Racine
>       > problem
>       >                       >       >       > Hi Pierre,
>       >                       >       >       > Thanks for the grid idea last night. I have a
>       > problem though, I
>       >                       > want to
>       >                       >       > have a 4m
>       >                       >       >       > by 4m cell sized grid over my buffer
>       > geometries which are in SRID
>       >                       >       > 4326. And
>       >                       >       >       > then I have another data set of 2D points
>       > which are also in SRID
>       >                       >       > 4326...
>       >                       >       >       > wondering how I can figure out from just a
>       > given (lat,long) which
>       >                       > cell
>       >                       >       > ID in the
>       >                       >       >       > buffer grid it would belong to? I am thinking
>       > that I might run into
>       >                       >       > "alignment
>       >                       >       >       > issues" because shouldn't the extent of the
>       > grid be exactly the
>       >                       > same
>       >                       >       > on the 2D
>       >                       >       >       > point cloud as well, so that the grid cell IDs
>       > will match? Unless I
>       >                       > am
>       >                       >       > missing
>       >                       >       >       > something here?
>       >                       >       >       > Cheers,
>       >                       >       >       > Ed
>       >                       >       >       > On Wed, Mar 21, 2012 at 8:46 PM, Pierre
>       > Racine
>       >                       >       >       > wrote:
>       >                       >       >       >       > I am not sure if this is possible, but I
>       > have computed (using
>       >                       >       > ST_Buffer)
>       >                       >       >       > a sort of
>       >                       >       >       >       > buffer around several LINESTRINGs.
>       > Now I would like to lay
>       >                       > some
>       >                       >       > sort
>       >                       >       >       > of grid of
>       >                       >       >       >       > say 1m^2 cell size on top of this
>       > collection of geometries
>       >                       > and
>       >                       >       > then
>       >                       >       >       > compute the
>       >                       >       >       >       > intersection... so in the end I would
>       > like to for example,
>       >                       > know
>       >                       >       > that grid
>       >                       >       >       > cell ID = 1
>       >                       >       >       >       > intersects with buffers 1 and 10, grid
>       > cell 2 intersects with
>       >                       > buffers
>       >                       >       > 7, 10
>       >                       >       >       > etc..
>       >                       >       >       >       > Is there a simple way of doing this in
>       > postgis? Maybe
>       >                       > someone
>       >                       >       > could
>       >                       >       >       > point me to
>       >                       >       >       >       > some documentation of how I can
>       > generate such a grid in
>       >                       > postgis
>       >                       >       > and
>       >                       >       >       > maybe
>       >                       >       >       >       > then I can use just ST_Intersect once I
>       > have these two
>       >                       >       > geometries?
>       >                       >       >       >       With the raster type you can now easily
>       > create a vector grid
>       >                       > like
>       >                       >       > this:
>       >                       >       > rwidth
>       >                       >       >       >                   FROM (SELECT
>       >                       > ST_AsRaster(ST_Extent(geom)::geometry,
>       >                       >       > 1.0,
>       >                       >       >       > 1.0) rast
>       >                       >       >       >                                FROM yourbuffertable
>       >                       >       >       >                               ) foo1
>       >                       >       >       >                  ) foo2;
>       >                       >       >       >       Make sure a spatial index exist on both
>       > tables:
>       >                       >       >       >       CREATE INDEX
>       > yourbuffertable_geom_idx  ON
>       >                       > yourbuffertable
>       >                       >       > USING
>       >                       >       >       > gist  (geom);
>       >                       >       >       >       CREATE INDEX vectorgrid _geom_idx
>       > ON vectorgrid USING
>       >                       > gist
>       >                       >       >       > (geom);
>       >                       >       >       >       You can then perform a normal intersect
>       > query:
>       >                       >       >       >       CREATE TABLE interresult AS
>       >                       >       >       >       SELECT b.bufferid, g.gridid,
>       > ST_Intersection(g.geom, b.geom)
>       >                       >       > geom
>       >                       >       >       >       FROM vectorgrid g, yourbuffertable b
>       >                       >       >       >       WHERE ST_Intersects(g.geom, b.geom);
>       >                       >       >       >       Pierre
>       > _______________________________________________
>       >                       >       >       >       postgis-users mailing list
>       >                       >       >       >       postgis-users at postgis.refractions.net
>       > http://postgis.refractions.net/mailman/listinfo/postgis-users
