[postgis-users] problem with restoring database postgis 2.0
John Callahan
john.callahan at udel.edu
Thu Mar 22 17:02:45 PDT 2012
Well, that makes sense. I was using the --data-only option because I did
not want to bring over the functions (since the functions already exist in
the new database through the postgis creation script.)
Is there a way to dump/restore only the data tables (including create
statements, indexes, sequences, privileges) and not the functions or
function comments? I ran into a problem recently while upgrading when I
had too many similar functions and postgis couldn't determine a unique
function at times.
- John
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
On Thu, Mar 22, 2012 at 7:17 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
> The pg_dump call is called with "--data-only" so you're not getting any
> table creation information. And since the new DB doesn't have any tables,
> restoring the data will result in an error.
> -bborie
> On 03/22/2012 04:14 PM, John Callahan wrote:
>> I having a problem with something that is usually straight forward. I am
>> moving a database from a Windows 2003 Server box to Windows 2008 Server.
>> Both are x64 but running 32bit Postgres 9.0.7. The new/destination
>> database runs the latest postgis 2.0 binaries (from March 19 or so) and
>> the
>> source/older database runs postgis 2.0 libraries from a few months ago.
>> On the new db, I installed postgres 9.0.7, then postgis 2.0 latest build,
>> which created my database. Of course, the database does not have any
>> tables at this point (just the functions, a few views.)
>> I run pg_dump on the source db as so:
>> pg_dump.exe --host localhost --port 5432 --username "username" --role
>> "myrole" --format plain --data-only --verbose --file
>> "C:\temp\webdata_20120315.sql" "mydb"
>> When I try to run the resulting sql on the new server, I get the following
>> error:
>> ERROR: relation<table_name> does not exist
>> If I use --inserts options in pg_dump, I still get the "relation does not
>> exist error" If I use pgAdmin to backup and restore (using the tar
>> format), the error is the same.
>> What am I missing? Thanks.
>> - John
>> ______________________________**_________________
>> postgis-users mailing list
>> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120322/d7d2c3e4/attachment.html>
