[postgis-users] problem with restoring database postgis 2.0
Bborie Park
bkpark at ucdavis.edu
Thu Mar 22 16:17:17 PDT 2012
The pg_dump call is called with "--data-only" so you're not getting any
table creation information. And since the new DB doesn't have any
tables, restoring the data will result in an error.
-bborie
On 03/22/2012 04:14 PM, John Callahan wrote:
> I having a problem with something that is usually straight forward. I am
> moving a database from a Windows 2003 Server box to Windows 2008 Server.
> Both are x64 but running 32bit Postgres 9.0.7. The new/destination
> database runs the latest postgis 2.0 binaries (from March 19 or so) and the
> source/older database runs postgis 2.0 libraries from a few months ago.
> On the new db, I installed postgres 9.0.7, then postgis 2.0 latest build,
> which created my database. Of course, the database does not have any
> tables at this point (just the functions, a few views.)
> I run pg_dump on the source db as so:
> pg_dump.exe --host localhost --port 5432 --username "username" --role
> "myrole" --format plain --data-only --verbose --file
> "C:\temp\webdata_20120315.sql" "mydb"
> When I try to run the resulting sql on the new server, I get the following
> error:
> ERROR: relation<table_name> does not exist
> If I use --inserts options in pg_dump, I still get the "relation does not
> exist error" If I use pgAdmin to backup and restore (using the tar
> format), the error is the same.
> What am I missing? Thanks.
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
