[postgis-users] ST_Mapalgebraexpr requires same alignment
Jose Carlos Martinez
jomarlla at cgf.upv.es
Fri Mar 23 04:14:30 PDT 2012
Hi again, I still dont know why Im getting 'NOTICE: The two rasters
provided do not have the same alignment. Returning NULL ' with
ST_Mapalgrebra. Im kind of stuck.
Any help would be appreciated.
On 22/03/2012 18:00, Jose Carlos Martinez wrote:
> Hi. Im trying to use mapalgebra between two layers with tiles, I get
> this warning:
> NOTICE: The two rasters provided do not have the same alignment.
> Returning NULL
> The resulted tiles are empty. Does ST_Mapalgebraexpr require same
> alignment? According to the docs I guess not but then dont know why im
> getting that message.
> In another example I didnt use st_union with the same result.
> insert into demdif (rast) select st_mapalgebraexpr (d1.rast, 1,
> st_union (d2.rast), 1, 'abs([rast1.val] - [rast2-val])','16BSI',
> 'FIRST', null, null,null) from dem200 d1, dem d2 where d1.rast &&
> d2.rast and st_relate (d1.rast::geometry, d2.rast::geometry,
> 'T********') group by d1.rid;
> Another issue is st_union (internally is st_mapalgebraexpr) is
> extremely slow. I can not manage raster layers bigger than a couple of
> thousand pixel in x or y even with 128 tiled blocks.
> Jose
> postgis-users mailing list
