[postgis-users] ST_Mapalgebraexpr requires same alignment
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Fri Mar 23 06:02:38 PDT 2012
> The resulted tiles are empty. Does ST_Mapalgebraexpr require same alignment?
> According to the docs I guess not but then dont know why im getting that
> message.
What in the doc let you think that it does not require same alignment? Is does...
> In another example I didnt use st_union with the same result.
> insert into demdif (rast) select st_mapalgebraexpr (d1.rast, 1, st_union (d2.rast),
> 1, 'abs([rast1.val] - [rast2-val])','16BSI', 'FIRST', null,
> null,null) from dem200 d1, dem d2 where d1.rast && d2.rast and st_relate
> (d1.rast::geometry, d2.rast::geometry, 'T********') group by d1.rid;
> Another issue is st_union (internally is st_mapalgebraexpr) is extremely slow. I
> can not manage raster layers bigger than a couple of thousand pixel in x or y
> even with 128 tiled blocks.
Right. This is documented:
http://postgis.org/documentation/manual-svn/RT_ST_Union.html
Pierre
