[postgis-users] osm2pgsql schema and table name
yvecai
yvecai at gmail.com
Fri Mar 30 09:54:20 PDT 2012
The only option to use -c without data loss is to use -d
'mynewandemptydatabase'.
Schema and tablenames are hard-coded in osm2pgsql: it is a highly
specialized tool.
Yves
Le 30/03/2012 18:38, Stephen Woodbridge a écrit :
> On 3/30/2012 11:59 AM, Francois Hugues wrote:
>> Hello user list,
>> A little question not directly related to postgis but i'm afraid
>> about making a mistake which could results in data loss when i will
>> use create option in osm2pgsql.
>> I did not find the way to specify the schema and table name i would
>> like to use to import data.
>> Does something like osm2pgsql -c schema.tablename could work ?
>> Else which are the default parameters of importation ? Public schema
>> ? File name as table name ?
>> I hope i'm not disturbing to much the mailing list,
>> Thanks in advance for your answers,
> $ man osm2pgsql
> OSM2PGSQL(1) OSM2PGSQL(1)
> NAME
> osm2pgsql - Openstreetmap data to PostgreSQL converter.
> SYNOPSIS
> osm2pgsql [options] planet.osm
> osm2pgsql [options] planet.osm.{gz,bz2}
> osm2pgsql [options] file1.osm file2.osm file3.osm
> DESCRIPTION
> This manual page documents briefly the osm2pgsql command.
> osm2pgsql imports data from OSM file(s) into a PostgreSQL
> database
> suitable for use by the Mapnik renderer.
> OSM planet snapshots can be downloaded from
> http://planet.openâ
> streetmap.org
> OPTIONS
> These programs follow the usual GNU command line syntax,
> with long
> options starting with two dashes (â-â). A summary of
> options is
> included below.
> -a|--append
> Add the OSM file into the database without removing
> existing
> data.
> -b|--bbox
> Apply a bounding box filter on the imported data Must be
> speciâ
> fied as: minlon,minlat,maxlon,maxlat e.g.
> --bbox
> -0.5,51.25,0.5,51.75
> -c|--create
> Remove existing data from the database. This is the
> default if
> --append is not specified.
> -d|--database
> The name of the PostgreSQL database to connect to
> (default:
> gis).
> -l|--latlong
> Store data in degrees of latitude & longitude.
> -m|--merc
> Store data in proper spherical mercator, not OSM merc
> -E|--proj num
> Use projection EPSG:num
> -u|--utf8-sanitize
> Repair bad UTF8 input data (present in planet dumps
> prior to
> August 2007). Adds about 10% overhead.
> -p|--prefix
> Prefix for table names (default planet_osm)
> -U|--username
> Postgresql user name.
> -W|--password
> Force password prompt.
> -H|--host
> Database server hostname or socket location.
> -P|--port
> Database server port.
> -h|--help
> Help information.
> Add -v to display supported projections.
> Use -E to access any espg projections
> (usually in
> /usr/share/proj/epsg)
> -v|--verbose
> Verbose output.
> SUPPORTED PROJECTIONS
> Latlong (-l) SRS: 4326 (none)
> WGS84 Mercator ( ) SRS: 3395 +proj=merc +datum=WGS84
> +k=1.0
> +units=m +over +no_defs
> Spherical Mercator (-m) SRS:900913 +proj=merc +a=6378137
> +b=6378137
> +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
> +nadgrids=@null
> +no_defs +over
> SEE ALSO
> proj(1), postgres(1).
> AUTHOR
> osm2pgsql was written by Jon Burgess and Artem Pavlenko.
> This manual page was written by Andreas Putzo
> <andreas at putzo.net>, for
> the Debian project (but may be used by others).
> April 12, 2008 OSM2PGSQL(1)
> postgis-users mailing list
