[postgis-users] topology performance improvement purpose
Jose Carlos Martinez Llario jomarlla at cgf.upv.es
Wed May 2 14:58:47 PDT 2012
wanted to share a though about improving the topology performance in
postgis.
Many of the functions are using EXECUTE instead of running directly
select commands.
In many cases this is need just because of the used of the schema name
of the topology primitive tables.
I found between 4 and 10 times improving performance some sentences. I
guessing it could be even better.
My question is if an approach like the following makes sense:
1.- With one command we can make the current topology schema the default
schema in search path,
2.- then working with topology
3.- Change search_path again when finishing the spatial analysis.
(the parameter of the topology name in the functions should be ignored
or removed)
I know it requires a lot of changes but currently the performance of the
persistent topology is too slow.
if one do that many functions can be run without EXECUTE. Spatial
analysis between different topologies is not possible which fits the
procedure.
What do you think Sandro?
Regards,
Jose
