[postgis-users] topology performance improvement purpose
Jose Carlos Martinez Llario
jomarlla at cgf.upv.es
Wed May 2 15:13:58 PDT 2012
i meant not the default schema in search_path but the first topology
working schema after public.
On 02/05/2012 23:58, Jose Carlos Martinez Llario wrote:
> Hi,
> wanted to share a though about improving the topology performance in
> postgis.
> Many of the functions are using EXECUTE instead of running directly
> select commands.
> In many cases this is need just because of the used of the schema
> name of the topology primitive tables.
> I found between 4 and 10 times improving performance some sentences. I
> guessing it could be even better.
> My question is if an approach like the following makes sense:
> 1.- With one command we can make the current topology schema the
> default schema in search path,
> 2.- then working with topology
> 3.- Change search_path again when finishing the spatial analysis.
> (the parameter of the topology name in the functions should be ignored
> or removed)
> I know it requires a lot of changes but currently the performance of
> the persistent topology is too slow.
> if one do that many functions can be run without EXECUTE. Spatial
> analysis between different topologies is not possible which fits the
> procedure.
> What do you think Sandro?
> Regards,
> Jose
> postgis-users mailing list
