[postgis-users] PostGIS 2.0 installation problem - Ubuntu 12.04
    jeffmeyer
    jeff at gwhat.org
    Fri May  4 16:02:45 PDT 2012
Hi all - apologies if this is posted elsewhere - I couldn't find anything
about it:
the postGIS2.0 README states:
To install PostGIS library and utilities, as postgres run::
  make install
But, make install requires su privileges (in order to create certain
directories) and the default postgres user account doesn't have this. Do I
need to elevate postgres to su? Isn't that a security issue?
Currently, when I make install as postgres, I get the following error:
cp: cannot create regular file `/usr/local/lib/_inst.32562_': Permission
denied
make[1]: *** [install-liblwgeom] Error 1
make[1]: Leaving directory `/var/lib/postgresql/postgis-2.0.1SVN/liblwgeom'
make: *** [install] Error 1
View this message in context: http://postgis.17.n6.nabble.com/PostGIS-2-0-installation-problem-Ubuntu-12-04-tp4953464.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
