[postgis-users] PostGIS 2.0 installation problem - Ubuntu 12.04
Stephen Woodbridge woodbri at swoodbridge.com
Fri May 4 22:00:52 PDT 2012
On 5/4/2012 8:47 PM, jeffmeyer wrote:
> Yes - I've tried all that&  install fails. Here's what comes next after sudo
> make install:
> postgres at jeffmetp:~/postgis-2.0.1SVN$ sudo make install
> [sudo] password for postgres:
> postgres is not in the sudoers file.  This incident will be reported.
> Bug filed - http://trac.osgeo.org/postgis/ticket/1804
Jeff,
Talk to your system admin or google how to setup sudo for the postgres
user. This is a system problem not a postgres problem. An alternative if
you have the root passwd is to to use:
su
make install
exit
-Steve
