[postgis-users] PostGIS 2.0 installation problem - Ubuntu 12.04
Jeff Meyer
jeff at gwhat.org
Sat May 5 10:38:27 PDT 2012
Hi Steve -
I am the system admin : ) and can go ahead and setup sudo for the postgres user.
Part of my goal here was to follow the instructions as strictly as possible for a clean Ubuntu install.
If the postgres user ins't a sudo'er out of the box, then the instructions should point out the need to add this.
It might be "understood" by *nix experts, but not so much for newer types.
Also, the instruction to do do all of these tasks as postgres is left out of the online docs, so it's tough to identify which is correct.
I'd be glad to file tickets or write alternative copy to make them consistent... as long as I know which is correct.
Thanks!
Jeff
>________________________________
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
>To: postgis-users at postgis.refractions.net
>Sent: Friday, May 4, 2012 10:00 PM
>Subject: Re: [postgis-users] PostGIS 2.0 installation problem - Ubuntu 12.04
>On 5/4/2012 8:47 PM, jeffmeyer wrote:
>> Yes - I've tried all that& install fails. Here's what comes next after sudo
>> make install:
>> postgres at jeffmetp:~/postgis-2.0.1SVN$ sudo make install
>> [sudo] password for postgres:
>> postgres is not in the sudoers file. This incident will be reported.
>> Bug filed - http://trac.osgeo.org/postgis/ticket/1804
>Jeff,
>Talk to your system admin or google how to setup sudo for the postgres
>user. This is a system problem not a postgres problem. An alternative if
>you have the root passwd is to to use:
>su
>make install
>exit
>-Steve
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120505/48ab860b/attachment.html>
