[postgis-users] Do I have to be a superuser to use postgis extensions?
Donovan Cameron
sault.don at gmail.com
Sat May 5 22:58:24 PDT 2012
I created a new role for a user in the database - 'saultdon':
*postgres:~> psql postgres -c 'CREATE ROLE saultdon LOGIN CREATEDB;'*
Then I created a new database for that user and a schema for future tables:
postgres:~> createdb -T template_postgis newdb -O saultdon
>From postgres user, newdb has postgis extensions - postgis,postgis_topology
installed and reports 'SELECT postgis_full_version();' correctly:
* POSTGIS="2.0.0 r9605" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8" TOPOLOGY RASTER*
*(1 row)*
When I to check the postgis version with the user saultdon, it says
postgis_topology not installed. I have to be superuser to use it.
saultdon:~> psql newdb -c 'SELECT postgis_full_version();'
2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8" RASTER*
*(1 row)*
*NOTICE: Function postgis_topology_scripts_installed() not found. Is
topology support enabled and topology.sql installed?*
saultdon:~> psql newdb -c '\dx' #it says it's installed and superuser
postgres can access it fine
* List of installed extensions*
* Name | Version | Schema |
Description *
* plpgsql | 1.0 | pg_catalog | PL/pgSQL procedural language*
* postgis | 2.0.0 | public | PostGIS geometry, geography,
and raster spatial types and functions*
* postgis_topology | 2.0.0 | topology | PostGIS topology spatial types
and functions*
*(3 rows)*
I can use the user saultdon to create a new database from scratch but not
to insert the postgis/postgis_topology extensions:
saultdon:~> createdb test
saultdon:~> psql test -c 'CREATE EXTENSION postgis;'
ERROR: permission denied to create extension "postgis"
HINT: Must be superuser to create this extension.
I'm fairly new to postgis/postgresql as a spatial data storage format. Do I
have to alter the saultdon role somehow to allow it to access the postgis
extensions. They seemed to be accessible exclusively from the superuser
postgres.
I am using openSUSE 12.1 (gnome) x64 and postgis 2.0/postgresl 9.3.1.
Thanks for any help or suggestions. I'm sure this is an elementary error
and I have scoured the postgresql and postgis manuals on what to do about
having to create a superuser just to use postgis without any luck.
Donovan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120505/13443ef8/attachment.html>
