[postgis-users] Do I have to be a superuser to use postgis extensions?
Sandro Santilli
strk at keybit.net
Sun May 6 01:31:16 PDT 2012
On Sat, May 05, 2012 at 10:58:24PM -0700, Donovan Cameron wrote:
> When I to check the postgis version with the user saultdon, it says
> postgis_topology not installed. I have to be superuser to use it.
> *NOTICE: Function postgis_topology_scripts_installed() not found. Is
> topology support enabled and topology.sql installed?*
Try
GRANT usage on schema topology to public;
Or variations of the above. When satisfied consider doing it on the
template database.
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
