[postgis-users] Do I have to be a superuser to use postgis extensions?
Donovan Cameron
sault.don at gmail.com
Sun May 6 11:30:14 PDT 2012
Using the GRANT sql worked. I read more about it in the postgresql manual.
Thanks.
GRANT USAGE ON SCHEMA topology TO PUBLIC;
Then It never fully took effect till I restarted the server,
*su -*
*rcpostgresql restart*
*exit*
Done.
Now, that part about giving access to PUBLIC on the template_postgis
database.
This is because without it, a non-superuser cannot create a database of
their own when using:
*createdb -T template_postgis newdb*
*createdb: database creation failed: ERROR: permission denied to copy
database "template_postgis"*
I tried using the similar GRANT for databases but it doesn't mention
anything about allowing users to copy. Only connect, so I tried that:
*GRANT CONNECT ON DATABASE template_postgis TO PUBLIC;*
But still, cannot create a database without being postgres user.
Not sure if I need to maybe make user of ALTER like so:
*ALTER DATABASE template_postgis OWNER TO PUBLIC;*
Or try,
*ALTER ROLE saultdon CREATEDB IN DATABASE template_postgis;*
Does one of those give me copy permissions because CONNECT hasn't.
Thanks for the help so far with changing schema privileges.
Donovan
On Sun, May 6, 2012 at 1:31 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Sat, May 05, 2012 at 10:58:24PM -0700, Donovan Cameron wrote:
> > When I to check the postgis version with the user saultdon, it says
> > postgis_topology not installed. I have to be superuser to use it.
> > *NOTICE: Function postgis_topology_scripts_installed() not found. Is
> > topology support enabled and topology.sql installed?*
> Try
> GRANT usage on schema topology to public;
> Or variations of the above. When satisfied consider doing it on the
> template database.
> --strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120506/35984b7c/attachment.html>
