[postgis-users] OSX PostGIS 9.1 installer not working
William Kyngesburye woklist at kyngchaos.com
Fri May 11 16:16:43 PDT 2012
If you are installing my PostGIS, it requires my Postgres package, the one that is installed in /usr/local/pgsql-9.x.  I don't support Postgres installed in /Library (I think that's the "official" postgres) or Apple's in /usr (new in Lion).
On May 11, 2012, at 5:15 PM, Jim deVos wrote:
> I'm unable to successfully run the postgis 9.1 graphical installer on my Mac (OSX 10.6.8).   Whenever I launch the installer it displays the following dialog "PostGIS requires PostgreSQL 9.1."  and then terminates.
> I've confirmed that PostgreSQL 9.1 is installed and appears to be working correctly.  Note that I also have an 8.4 install running also (8.4 runs on the default port 5432, and the v9.1 instance runs on port 5433).  I've tried stopping the 8.4 service and starting the 9.1 instance on the default port, but I still get the error.
> I read a similar thread (issues w/ postgis 9.0 installer)  that claimed that the installer looks for "/usr/local/pgsql-9.0/lib/libpq.5.3.dylib".  I don't have this file (or even this directory) on my machine,  but I do have "/Library/PostgreSQL/9.1/lib/libpq.5.4.dylib", if that matters, and it does appear that my postgresql 9.1 installation is working (i'm able to connect, create tables, etc.).
> Anybody know what I'm doing wrong?
> postgis-users mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
