[postgis-users] break lines at intersections
Stephen V. Mather
svm at clevelandmetroparks.com
Thu May 17 09:17:27 PDT 2012
Also, ST_DWithin is a bounding box test, so its fast but not accurate.
Youll want to do a second test with ST_Distance to get the actual distance
after gathering up everything that results in true for ST_DWithin.
Best,
Steve
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
<http://www.clemetparks.com/> clevelandmetroparks.com
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Pedro
Costa
Sent: Thursday, May 17, 2012 11:54 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] break lines at intersections
i found the error. the parallels are a less then 3 meters...
thanks
Em 17-05-2012 16:43, Pedro Costa escreveu:
I'm already tried this function but with no good results, I do not
understand why.
You can see an example in the attached image. The streets are red lines. The
parallel purple and what I want to clear yellow.
Any idea ?
I tried the st_dwithin like this:
create table street8 as (SELECT paralell.geom FROM parallel,street WHERE
st_dwithin(paralell.geom, streets.the_geom, 2.99 ))
The 'line erros' that i want to delete are a less than 3 meters from
streets...
thanks
Em 17-05-2012 16:32, Nicolas Ribot escreveu:
Yes, it should be:
st_dwithin will help you to find all lines from a table within a certain
distance to other lines.
Nicolas
On 17 May 2012 17:23, Pedro Costa <pedrocostaarma at sapo.pt> wrote:
Great Nicolos, works...
It is possible select lines from one table a less than 3 meters from lines
from another table?and delete them...
thanks
Em 17-05-2012 15:41, Nicolas Ribot escreveu:
Hi Pedro,
select (st_dump(st_union(geom))).geom from lines;
will cut your network of lines at intersections.
Nicolas
On 17 May 2012 11:57, Pedro Costa <pedrocostaarma at sapo.pt> wrote:
does anyone know how I can cut the lines at intersectionslike the image
attached?
I can´t install postgis 2.0 for now....
I see a few examples with st_union and st_dump but i don't understand...
Thanks
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120517/6ec0628a/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120517/6ec0628a/attachment.png>
