[postgis-users] break lines at intersections
Pedro Costa pedrocostaarma at sapo.pt
Thu May 17 08:53:30 PDT 2012
i found the error. the parallels are a less then 3 meters...
thanks
Em 17-05-2012 16:43, Pedro Costa escreveu:
> I'm already tried this function but with no good results, I do not
> understand why.
> You can see an example in the attached image. The streets are red
> lines. The parallel purple and what I want to clear yellow.
> Any idea ?
> I tried the st_dwithin like this:
> create table street8 as (SELECT paralell.geom FROM parallel,street
> WHERE st_dwithin(paralell.geom, streets.the_geom, 2.99 ))
> The 'line erros' that i want to delete are a less than 3 meters from
> streets...
> thanks
> Em 17-05-2012 16:32, Nicolas Ribot escreveu:
>> Yes, it should be:
>> st_dwithin will help you to find all lines from a table within a
>> certain distance to other lines.
>> Nicolas
>> On 17 May 2012 17:23, Pedro Costa <pedrocostaarma at sapo.pt
>> <mailto:pedrocostaarma at sapo.pt>> wrote:
>>     Great Nicolos, works...
>>     It is possible select lines from one table a less than 3 meters
>>     from lines from another table?and delete them...
>>     thanks
>>     Em 17-05-2012 15:41, Nicolas Ribot escreveu:
>>>     Hi Pedro,
>>>     select (st_dump(st_union(geom))).geom from lines;
>>>     will cut your network of lines at intersections.
>>>     Nicolas
>>>     On 17 May 2012 11:57, Pedro Costa <pedrocostaarma at sapo.pt
>>>         does anyone know how I can cut the lines at
>>>         intersectionslike the image attached?
>>>         I can´t install postgis 2.0 for now....
>>>         I see a few examples with st_union and st_dump but i don't
>>>         understand...
>>>         Thanks
>>>         _______________________________________________
>>>         postgis-users mailing list
>>>         postgis-users at postgis.refractions.net
>>>         <mailto:postgis-users at postgis.refractions.net>
>>>         http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>     postgis-users at postgis.refractions.net  <mailto:postgis-users at postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120517/c3078b4b/attachment.html>
