[postgis-users] break lines at intersections
Pedro Costa
pedrocostaarma at sapo.pt
Thu May 17 08:43:40 PDT 2012
I'm already tried this function but with no good results, I do not
understand why.
You can see an example in the attached image. The streets are red lines.
The parallel purple and what I want to clear yellow.
Any idea ?
I tried the st_dwithin like this:
create table street8 as (SELECT paralell.geom FROM parallel,street WHERE
st_dwithin(paralell.geom, streets.the_geom, 2.99 ))
The 'line erros' that i want to delete are a less than 3 meters from
streets...
thanks
Em 17-05-2012 16:32, Nicolas Ribot escreveu:
> Yes, it should be:
> st_dwithin will help you to find all lines from a table within a
> certain distance to other lines.
> Nicolas
> On 17 May 2012 17:23, Pedro Costa <pedrocostaarma at sapo.pt
> <mailto:pedrocostaarma at sapo.pt>> wrote:
> Great Nicolos, works...
> It is possible select lines from one table a less than 3 meters
> from lines from another table?and delete them...
> thanks
> Em 17-05-2012 15:41, Nicolas Ribot escreveu:
>> Hi Pedro,
>> select (st_dump(st_union(geom))).geom from lines;
>> will cut your network of lines at intersections.
>> Nicolas
>> On 17 May 2012 11:57, Pedro Costa <pedrocostaarma at sapo.pt
>> does anyone know how I can cut the lines at intersectionslike
>> the image attached?
>> I can´t install postgis 2.0 for now....
>> I see a few examples with st_union and st_dump but i don't
>> understand...
>> Thanks
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120517/d89b14ae/attachment.html>
Type: image/bmp
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120517/d89b14ae/attachment.bin>
