[postgis-users] PostGis Raster and GDAL 1.9
David B�langer
belanger_david at live.ca
Thu May 17 17:13:06 PDT 2012
I stored DEM raster data in PostGIS 2.0 and I used gdal_translate
(with mode=2) to extract a mosaic of tiles. When I’m using GDAL 1.8 is
working but when I’m using GDAL 1.9 I can see the values of pixel for
just one tile. For example I uploaded in the database a tile with an
attribute filename=056n05_w and an other tile with an filename=056n05_e
and I executed the command with GDAL 1.8 and GDAL 1.9:
gdal_translate" -a_nodata "-32767" -of GTIFF "PG:host=myhost
port=14070 dbname='mybd' user='myuser' password='mypassword'
schema='myschema'table='Elevation' mode=2 where=\"filename LIKE
\'%056n05%\'\" " 056N05.tif
With GDAL 1.8 I obtained a mosaic of 2 tiles (the result expected)
but with GDAL 1.9, I obtained a raster with the same extent but only the
values of the tile 056n05_w are present. The pixels of the tile
056n05_w have a value 0.
I tried the stable version 1.9 MSVC2008 (Win32) and development version available today at http://www.gisinternals.com/sdk/
and I have still the same problem. For your information, I'm running
GDAL on windows7 and PostGIS 2.0 is installed on a Linux server. I tried
many version of GDAL 1.9 and I always have the same problem. The
version 1.8 is working very well but I would like to take advantage of
the improvements in the last version because I'm working on a project
where processing time is very important.
Does anybody have any idea about this problem ?
Thanks
David Bélanger
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120517/2e741b27/attachment.html>
