[postgis-users] PostGis Raster and GDAL 1.9
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Sat May 19 10:55:47 PDT 2012
Hi David,
Do you have a "rid" column in your table with unique values?
Pierre
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of David B?langer
> Sent: Thursday, May 17, 2012 8:13 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] PostGis Raster and GDAL 1.9
> Hi,
> I stored DEM raster data in PostGIS 2.0 and I used gdal_translate (with mode=2)
> to extract a mosaic of tiles. When I’m using GDAL 1.8 is working but when I’m
> using GDAL 1.9 I can see the values of pixel for just one tile. For example I
> uploaded in the database a tile with an attribute filename=056n05_w and an
> other tile with an filename=056n05_e and I executed the command with GDAL
> 1.8 and GDAL 1.9:
> gdal_translate" -a_nodata "-32767" -of GTIFF "PG:host=myhost port=14070
> dbname='mybd' user='myuser' password='mypassword'
> schema='myschema'table='Elevation' mode=2 where=\"filename LIKE
> \'%056n05%\'\" " 056N05.tif
> With GDAL 1.8 I obtained a mosaic of 2 tiles (the result expected) but with GDAL
> 1.9, I obtained a raster with the same extent but only the values of the tile
> 056n05_w are present. The pixels of the tile 056n05_w have a value 0.
> I tried the stable version 1.9 MSVC2008 (Win32) and development version
> available today at http://www.gisinternals.com/sdk/
> <https://email.nrcan.gc.ca/owa/redir.aspx?C=OzXx4wlk90m3TV7W8fzG7_FxObj
> PB88I1bAwXOtZColSmDyhIvj_1yhbCVJUJ0vrnCWWTuivB9Y.&URL=http://www.g
> isinternals.com/sdk/> and I have still the same problem. For your information,
> I'm running GDAL on windows7 and PostGIS 2.0 is installed on a Linux server. I
> tried many version of GDAL 1.9 and I always have the same problem. The version
> 1.8 is working very well but I would like to take advantage of the improvements
> in the last version because I'm working on a project where processing time is
> very important.
> Does anybody have any idea about this problem ?
> Thanks
> David Bélanger
