[postgis-users] PostGis Raster and GDAL 1.9
David B�langer belanger_david at live.ca
Tue May 22 07:25:09 PDT 2012
Hi Pierre,
Yes I have a unique
rid (Integer) with sequential number. I used the tool raster2pgsql.exe
to upload the data in the database. I uploaded 2 files
056n05_0100_deme.tif
056n05_0100_demw.tif
"C:\Program
Files\PostgreSQL\9.1\bin\raster2pgsql.exe" -I -e -Y -F -s 4269
e:\dir\*.tif dbelange.elevationTest | "psql.exe" -U myuser -d myDB -h
myhost -p 14070
I used this command to extract data:
"C:\Program
Files\GDAL\gdal_translate" -a_nodata "-32767" -of GTIFF
"PG:host=myhost port=14070 dbname='myDB' user='myuser'
password='mypassword' schema='dbelange' table='elevationTest' mode=2
where=\"filename
LIKE \'%056n05%\'\" " 056N05_testGDAL1.9.tif
Like I said it’s working very well with gdal 1.8
I can send you the 2 files If you want to try on your side.
Do you have another idea?
David
> From: Pierre.Racine at sbf.ulaval.ca
> To: postgis-users at postgis.refractions.net
> Date: Sat, 19 May 2012 13:55:47 -0400
> Subject: Re: [postgis-users] PostGis Raster and GDAL 1.9
> Hi David,
> Do you have a "rid" column in your table with unique values?
> Pierre
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> > bounces at postgis.refractions.net] On Behalf Of David B?langer
> > Sent: Thursday, May 17, 2012 8:13 PM
> > Subject: [postgis-users] PostGis Raster and GDAL 1.9
> > Hi,
> > I stored DEM raster data in PostGIS 2.0 and I used gdal_translate (with mode=2)
> > to extract a mosaic of tiles. When I’m using GDAL 1.8 is working but when I’m
> > using GDAL 1.9 I can see the values of pixel for just one tile. For example I
> > uploaded in the database a tile with an attribute filename=056n05_w and an
> > other tile with an filename=056n05_e and I executed the command with GDAL
> > 1.8 and GDAL 1.9:
> > gdal_translate" -a_nodata "-32767" -of GTIFF  "PG:host=myhost port=14070
> > dbname='mybd' user='myuser' password='mypassword'
> > schema='myschema'table='Elevation' mode=2 where=\"filename LIKE
> > \'%056n05%\'\" " 056N05.tif
> > With GDAL 1.8 I obtained a mosaic of 2 tiles (the result expected) but with GDAL
> > 1.9, I obtained a raster with the same extent but only the values of the tile
> > 056n05_w are present. The pixels of the tile 056n05_w have a value 0.
> > I tried the stable version 1.9 MSVC2008 (Win32) and development version
> > available today  at  http://www.gisinternals.com/sdk/
> > <https://email.nrcan.gc.ca/owa/redir.aspx?C=OzXx4wlk90m3TV7W8fzG7_FxObj
> > PB88I1bAwXOtZColSmDyhIvj_1yhbCVJUJ0vrnCWWTuivB9Y.&URL=http://www.g
> > isinternals.com/sdk/>  and I have still the same problem. For your information,
> > I'm running GDAL on windows7 and PostGIS 2.0 is installed on a Linux server. I
> > tried many version of GDAL 1.9 and I always have the same problem. The version
> > 1.8 is working very well but I would like to take advantage of the improvements
> > in the last version because I'm working on a project where processing time is
> > very important.
> > Does anybody have any idea about this problem ?
> > Thanks
> > David Bélanger
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120522/f24c979d/attachment.html>
