[postgis-users] tiger_geocoder import error
Jeff Rossi rossi.jeff at gmail.com
Tue May 22 04:45:46 PDT 2012
Sorry if this is a double post, had an issue with my mail server and had to
use my personal email.
This is my first project with postgresql/postgis and it is possible and
maybe even probable that I made an error.  I used pgadmin to generate import
scripts by state and started with florida. The errors are below:
COMMIT
NOTICE:  INSERT INTO
tiger_data.fl_tabblock(the_geom,intptlon,intptlat,awater,aland,funcstat,uace,ur,mtfcc,name,tabblock_id,blockce,tractce,countyfp,statefp)
SELECT
the_geom,intptlon10,intptlat10,awater10,aland10,funcstat10,uatyp10,uace10,ur10,mtfcc10,name10,tabblock_id,blockce10,tractce10,countyfp10,statefp10
FROM tiger_staging.fl_tabblock10;
CONTEXT:  SQL function "loader_load_staged_data" statement 1
ERROR:  INSERT has more expressions than target columns
LINE 1: ...name10,tabblock_id,blockce10,tractce10,countyfp10,statefp10 ...
QUERY:  INSERT INTO
SELECT
CONTEXT:  PL/pgSQL function "loader_load_staged_data" line 24 at EXECUTE
statement
It appears to me that the extra column is uatyp10
Many Thanks for your Assistance,
Jeff
View this message in context: http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
