[postgis-users] tiger_geocoder import error
Mario Sileone
msileone at gmail.com
Tue May 22 05:47:03 PDT 2012
Dear Jeff:
according to the error detailed
ERROR: INSERT has more expressions than target columns
You Have:
the_geom,intptlon,intptlat,awater,aland,funcstat,uace,ur,mtfcc,name,tabblock_id,blockce,tractce,countyfp,statefp
Which count 15 expressions and
the_geom,intptlon10,intptlat10,awater10,aland10,funcstat10,uatyp10,uace10,ur10,mtfcc10,name10,tabblock_id,blockce10,tractce10,countyfp10,statefp10
are 16 values.
So, or You have a missin expression or one more value, check this.
Best Regards
El 22/05/2012 8:45, Jeff Rossi escribió:
> Sorry if this is a double post, had an issue with my mail server and had to
> use my personal email.
> This is my first project with postgresql/postgis and it is possible and
> maybe even probable that I made an error. I used pgadmin to generate import
> scripts by state and started with florida. The errors are below:
> COMMIT
> NOTICE: INSERT INTO
> tiger_data.fl_tabblock(the_geom,intptlon,intptlat,awater,aland,funcstat,uace,ur,mtfcc,name,tabblock_id,blockce,tractce,countyfp,statefp)
> SELECT
> FROM tiger_staging.fl_tabblock10;
> CONTEXT: SQL function "loader_load_staged_data" statement 1
> LINE 1: ...name10,tabblock_id,blockce10,tractce10,countyfp10,statefp10 ...
> QUERY: INSERT INTO
> SELECT
> CONTEXT: PL/pgSQL function "loader_load_staged_data" line 24 at EXECUTE
> statement
> It appears to me that the extra column is uatyp10
> Many Thanks for your Assistance,
> Jeff
> View this message in context: http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
Mario Sileone
