[postgis-users] tiger_geocoder import error
Jeff Rossi rossi.jeff at gmail.com
Tue May 22 08:46:15 PDT 2012
Any idea how I can get the 480K records from tiger_staging.fl_tabblock10
to  tiger_data.fl_tabblock
On Tue, May 22, 2012 at 8:47 AM, Mario Sileone [via PostGIS] <
ml-node+s17n4997640h51 at n6.nabble.com> wrote:
> Dear Jeff:
>         according to the error detailed
> ERROR:  INSERT has more expressions than target columns
>         You Have:
> the_geom,intptlon,intptlat,awater,aland,funcstat,uace,ur,mtfcc,name,tabblock_id,blockce,tractce,countyfp,statefp
> Which count 15 expressions and
> the_geom,intptlon10,intptlat10,awater10,aland10,funcstat10,uatyp10,uace10,ur10,mtfcc10,name10,tabblock_id,blockce10,tractce10,countyfp10,statefp10
> are 16 values.
> So, or You have a missin expression or one more value, check this.
> Best Regards
> El 22/05/2012 8:45, Jeff Rossi escribió:
> > Sorry if this is a double post, had an issue with my mail server and had
> to
> > use my personal email.
> > This is my first project with postgresql/postgis and it is possible and
> > maybe even probable that I made an error.  I used pgadmin to generate
> import
> > scripts by state and started with florida. The errors are below:
> > COMMIT
> > NOTICE:  INSERT INTO
> tiger_data.fl_tabblock(the_geom,intptlon,intptlat,awater,aland,funcstat,uace,ur,mtfcc,name,tabblock_id,blockce,tractce,countyfp,statefp)
> > SELECT
> > FROM tiger_staging.fl_tabblock10;
> > CONTEXT:  SQL function "loader_load_staged_data" statement 1
> > LINE 1: ...name10,tabblock_id,blockce10,tractce10,countyfp10,statefp10
> > QUERY:  INSERT INTO
> > SELECT
> > CONTEXT:  PL/pgSQL function "loader_load_staged_data" line 24 at EXECUTE
> > statement
> > It appears to me that the extra column is uatyp10
> > Many Thanks for your Assistance,
> > Jeff
> > View this message in context:
> http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634.html
> > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > postgis-users mailing list
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=4997640&i=0>
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Mario Sileone
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4997640&i=1>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p4997640.html
>  To unsubscribe from tiger_geocoder import error, click here<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4997634&code=cm9zc2kuamVmZkBnbWFpbC5jb218NDk5NzYzNHwtNjQ5NjEzMjk4>
> NAML<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Regards
Jeff Rossi
Intouch MVC
1506 Tuscaloosa Ave
Holly Hill, FL 32117
(386) 226-8979
View this message in context: http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p4997655.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120522/8e822353/attachment.html>
