[postgis-users] tiger_geocoder import error
    Paragon Corporation
    lr at pcorp.us
    Tue May 22 12:24:58 PDT 2012
Can you put in a ticket for this.  I suspect its a bug.  The census blocks
piece was the last piece to go in and when I was testing I was loading
mostly separately.
http://trac.osgeo.org/postgis/
Set to tiger_geocoder for component and it will be assigned to me.
Also are you using tiger_2010 or tiger_2011.  I haven't fixed census blocks
for 2011 yet.
Thanks,
Regina
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Jeff
Rossi
Sent: Tuesday, May 22, 2012 2:11 PM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] tiger_geocoder import error
I can make a query to finish the import, but how would I fix the import
script so I don't have issues with the 49 other states.
On Tue, May 22, 2012 at 1:51 PM, Stephen Woodbridge [via PostGIS] <[hidden
email]> wrote:
Depends on if you just want to rename them or copy them!
Rename like:
create schema tiger_data;
begin;
-- first rename the table
alter table tiger_staging.fl_tabblock10 rename fl_tabblock;
-- then move it to the new schema
alter table tiger_staging.fl_tabblock set schema tiger_data;
commit;
If there are name conflicts you can move it to the new schema then
rename it. If you want to copy the data then look at commands like:
create table tiger_data.fl_tabblock as select * from
tiger_staging.fl_tabblock10;
or
insert into tiger_data.fl_tabblock (<column_list>) select <column_list>
from tiger_staging.fl_tabblock10;
-Steve W
On 5/22/2012 11:46 AM, Jeff Rossi wrote:
> Any idea how I can get the 480K records from tiger_staging.fl_tabblock10
> On Tue, May 22, 2012 at 8:47 AM, Mario Sileone [via PostGIS] <[hidden
> email] </user/SendEmail.jtp?type=node&node=4997655&i=0>> wrote:
>     Dear Jeff:
>              according to the error detailed
>     ERROR:  INSERT has more expressions than target columns
>              You Have:
the_geom,intptlon,intptlat,awater,aland,funcstat,uace,ur,mtfcc,name,tabblock
_id,blockce,tractce,countyfp,statefp
>     Which count 15 expressions and
the_geom,intptlon10,intptlat10,awater10,aland10,funcstat10,uatyp10,uace10,ur
10,mtfcc10,name10,tabblock_id,blockce10,tractce10,countyfp10,statefp10
>     are 16 values.
>     So, or You have a missin expression or one more value, check this.
>     Best Regards
>     El 22/05/2012 8:45, Jeff Rossi escribió:
>      > Sorry if this is a double post, had an issue with my mail server
>     and had to
>      > use my personal email.
>      > This is my first project with postgresql/postgis and it is
>     possible and
>      > maybe even probable that I made an error.  I used pgadmin to
>     generate import
>      > scripts by state and started with florida. The errors are below:
>      > COMMIT
>      > NOTICE:  INSERT INTO
tiger_data.fl_tabblock(the_geom,intptlon,intptlat,awater,aland,funcstat,uace
,ur,mtfcc,name,tabblock_id,blockce,tractce,countyfp,statefp)
>      > SELECT
>      > FROM tiger_staging.fl_tabblock10;
>      > CONTEXT:  SQL function "loader_load_staged_data" statement 1
>      > LINE 1:
>     ...name10,tabblock_id,blockce10,tractce10,countyfp10,statefp10 ...
>      > QUERY:  INSERT INTO
>      > SELECT
>      > CONTEXT:  PL/pgSQL function "loader_load_staged_data" line 24 at
>     EXECUTE
>      > statement
>      > It appears to me that the extra column is uatyp10
>      > Many Thanks for your Assistance,
>      > Jeff
>      > View this message in context:
http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634.html
>      > Sent from the PostGIS - User mailing list archive at Nabble.com.
>      > _______________________________________________
>      > postgis-users mailing list
>      > [hidden email]
>     <http://user/SendEmail.jtp?type=node
<http://user/SendEmail.jtp?type=node&node=4997640&i=0> &node=4997640&i=0>
>      > http://postgis.refractions.net/mailman/listinfo/postgis-users
>     Mario Sileone
>     [hidden email] <http://user/SendEmail.jtp?type=node
<http://user/SendEmail.jtp?type=node&node=4997640&i=1> &node=4997640&i=1>
>     If you reply to this email, your message will be added to the
>     discussion below:
http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p499764
0.html
>     To unsubscribe from tiger_geocoder import error, click here.
>     NAML
<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer
&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicName
space-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.Node
Namespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_email
s%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> Regards
> Jeff Rossi
> Intouch MVC
> 1506 Tuscaloosa Ave
> Holly Hill, FL 32117
> <a href="tel:%28386%29%20226-8979" value="+13862268979"
target="_blank">(386) 226-8979
> View this message in context: Re: tiger_geocoder import error
<http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p49976
55.html>
> <http://postgis.17.n6.nabble.com/PostGIS-User-f3516033.html> at
Nabble.com.
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4997671&i=0>
[hidden email] <http://user/SendEmail.jtp?type=node&node=4997671&i=1>
  _____
If you reply to this email, your message will be added to the discussion
below:
http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p499767
1.html
NAML
Regards
Jeff Rossi
Intouch MVC
1506 Tuscaloosa Ave
(386) 226-8979
  _____
72.html> tiger_geocoder import error
<http://postgis.17.n6.nabble.com/PostGIS-User-f3516033.html> mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120522/bb6045ec/attachment.html>
