[postgis-users] tiger_geocoder import error
Jeff Rossi
rossi.jeff at gmail.com
Tue May 22 11:11:23 PDT 2012
I can make a query to finish the import, but how would I fix the import
script so I don't have issues with the 49 other states.
On Tue, May 22, 2012 at 1:51 PM, Stephen Woodbridge [via PostGIS] <
ml-node+s17n4997671h12 at n6.nabble.com> wrote:
> Depends on if you just want to rename them or copy them!
> Rename like:
> create schema tiger_data;
> begin;
> -- first rename the table
> alter table tiger_staging.fl_tabblock10 rename fl_tabblock;
> -- then move it to the new schema
> alter table tiger_staging.fl_tabblock set schema tiger_data;
> commit;
> If there are name conflicts you can move it to the new schema then
> rename it. If you want to copy the data then look at commands like:
> create table tiger_data.fl_tabblock as select * from
> tiger_staging.fl_tabblock10;
> or
> insert into tiger_data.fl_tabblock (<column_list>) select <column_list>
> from tiger_staging.fl_tabblock10;
> -Steve W
> On 5/22/2012 11:46 AM, Jeff Rossi wrote:
> > Any idea how I can get the 480K records from tiger_staging.fl_tabblock10
> > On Tue, May 22, 2012 at 8:47 AM, Mario Sileone [via PostGIS] <[hidden
> > email] </user/SendEmail.jtp?type=node&node=4997655&i=0>> wrote:
> > Dear Jeff:
> > according to the error detailed
> > ERROR: INSERT has more expressions than target columns
> > You Have:
> the_geom,intptlon,intptlat,awater,aland,funcstat,uace,ur,mtfcc,name,tabblock_id,blockce,tractce,countyfp,statefp
> > Which count 15 expressions and
> the_geom,intptlon10,intptlat10,awater10,aland10,funcstat10,uatyp10,uace10,ur10,mtfcc10,name10,tabblock_id,blockce10,tractce10,countyfp10,statefp10
> > are 16 values.
> > So, or You have a missin expression or one more value, check this.
> > Best Regards
> > El 22/05/2012 8:45, Jeff Rossi escribió:
> > > Sorry if this is a double post, had an issue with my mail server
> > and had to
> > > use my personal email.
> > > This is my first project with postgresql/postgis and it is
> > possible and
> > > maybe even probable that I made an error. I used pgadmin to
> > generate import
> > > scripts by state and started with florida. The errors are below:
> > > COMMIT
> > > NOTICE: INSERT INTO
> tiger_data.fl_tabblock(the_geom,intptlon,intptlat,awater,aland,funcstat,uace,ur,mtfcc,name,tabblock_id,blockce,tractce,countyfp,statefp)
> > > SELECT
> > > FROM tiger_staging.fl_tabblock10;
> > > CONTEXT: SQL function "loader_load_staged_data" statement 1
> > > LINE 1:
> > ...name10,tabblock_id,blockce10,tractce10,countyfp10,statefp10 ...
> > > QUERY: INSERT INTO
> > > SELECT
> > > CONTEXT: PL/pgSQL function "loader_load_staged_data" line 24 at
> > EXECUTE
> > > statement
> > > It appears to me that the extra column is uatyp10
> > > Many Thanks for your Assistance,
> > > Jeff
> > > View this message in context:
> http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634.html
> > > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > > _______________________________________________
> > > postgis-users mailing list
> > > [hidden email]
> > <http://user/SendEmail.jtp?type=node&node=4997640&i=0>
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > Mario Sileone
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=4997640&i=1>
> > If you reply to this email, your message will be added to the
> > discussion below:
> http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p4997640.html
> > To unsubscribe from tiger_geocoder import error, click here.
> > NAML
> http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> > Regards
> > Jeff Rossi
> > Intouch MVC
> > 1506 Tuscaloosa Ave
> > Holly Hill, FL 32117
> > (386) 226-8979
> > View this message in context: Re: tiger_geocoder import error
> http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p4997655.html>
> > <http://postgis.17.n6.nabble.com/PostGIS-User-f3516033.html> at
> Nabble.com.
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=4997671&i=0>
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4997671&i=1>
> If you reply to this email, your message will be added to the discussion
> below:
> http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p4997671.html
> To unsubscribe from tiger_geocoder import error, click here<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4997634&code=cm9zc2kuamVmZkBnbWFpbC5jb218NDk5NzYzNHwtNjQ5NjEzMjk4>
> NAML<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Regards
Jeff Rossi
Intouch MVC
1506 Tuscaloosa Ave
(386) 226-8979
View this message in context: http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p4997672.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120522/8634b932/attachment.html>
