[postgis-users] tiger_geocoder import error
Paragon Corporation lr at pcorp.us
Tue May 22 19:19:52 PDT 2012
Jeff,
Which point for example are you trying to reverse geocode? Mine seems to be
working fine but I just have MA data loaded.
Also are you using the tiger_2010 or tiger_2011.  In the 2.1 trunk I have
tiger_2011 and even if you are on 2.0 probably the best to use since its
designed for the newer tiger data and the newer tiger data has many data
quality improvements I am told.  They also changed the fields quite a bit
between tiger_2010 and tiger_2011 releases and no longer offer the state by
state folders http structure so I had to change the loader quite a bit to
handle that they have all the states now in a single folder.
Can you also let me know what version of PostGIS and PostgreSQL you are
using?
Thanks,
Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Jeff Rossi
> Sent: Tuesday, May 22, 2012 4:53 PM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] tiger_geocoder import error
> I submitted a ticket, thank you
> I modified the query and got the data inserted.
> Is working ok for geocoding, but reverse geocoding does not
> report street number, street or type
> http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp
4997634p4997681.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
