[postgis-users] tiger_geocoder import error
Jeff Rossi
rossi.jeff at gmail.com
Wed May 23 05:37:37 PDT 2012
psql --version
psql (PostgreSQL) 9.1.3
postgis-1.5 from ubuntu repo
I have the 2010 tiger data, and added the tiger geocoder from the 2.0
download.
Perhaps my issue is due to the errors with the import.
Thanks,
Jeff
On Tue, May 22, 2012 at 10:20 PM, Paragon Corporation-2 [via PostGIS] <
ml-node+s17n4997688h39 at n6.nabble.com> wrote:
> Jeff,
> Which point for example are you trying to reverse geocode? Mine seems to
> be
> working fine but I just have MA data loaded.
> Also are you using the tiger_2010 or tiger_2011. In the 2.1 trunk I have
> tiger_2011 and even if you are on 2.0 probably the best to use since its
> designed for the newer tiger data and the newer tiger data has many data
> quality improvements I am told. They also changed the fields quite a bit
> between tiger_2010 and tiger_2011 releases and no longer offer the state
> by
> state folders http structure so I had to change the loader quite a bit to
> handle that they have all the states now in a single folder.
> Can you also let me know what version of PostGIS and PostgreSQL you are
> using?
> Thanks,
> Regina
> http://www.postgis.us
View this message in context: http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p4997699.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120523/5f541db3/attachment.html>
