[postgis-users] tiger_geocoder import error
Paragon Corporation lr at pcorp.us
Wed May 23 11:55:55 PDT 2012
The reverse geocoder uses zcta table where as the geocoder does not.  Verify that data is filled.  There should be one for each state you load like fl_zcta.
That load I added in 2.0.0 so it should be there (assuming you have the 2.0.0 tar ball)  and be part of the loading, but not sure I tested it on Linux though so I might have an error somewhere there.  You should see it in the loader_lookuptables.
Thanks for testing,
Regina
http://www.postgis.us
  _____
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Jeff Rossi
Sent: Wednesday, May 23, 2012 8:38 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] tiger_geocoder import error
psql --version
psql (PostgreSQL) 9.1.3
postgis-1.5 from ubuntu repo
I have the 2010 tiger data, and added the tiger geocoder from the 2.0 download.
Perhaps my issue is due to the errors with the import.
Thanks,
Jeff
On Tue, May 22, 2012 at 10:20 PM, Paragon Corporation-2 [via PostGIS] <[hidden email]> wrote:
Jeff,
Which point for example are you trying to reverse geocode? Mine seems to be
working fine but I just have MA data loaded.
Also are you using the tiger_2010 or tiger_2011. ��In the 2.1 trunk I have
tiger_2011 and even if you are on 2.0 probably the best to use since its
designed for the newer tiger data and the newer tiger data has many data
quality improvements I am told. ��They also changed the fields quite a bit
between tiger_2010 and tiger_2011 releases and no longer offer the state by
state folders http structure so I had to change the loader quite a bit to
handle that they have all the states now in a single folder.
Can you also let me know what version of PostGIS and PostgreSQL you are
using?
Thanks,
Regina
  _____
View this message in context: Re:  <http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p4997699.html> tiger_geocoder import error
Sent from the PostGIS -  <http://postgis.17.n6.nabble.com/PostGIS-User-f3516033.html> User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120523/38823c55/attachment.html>
